200e
250e question
250e question
2008-08-20 by kkonkkrete
How much does the Arbitrary Function Generator remember at power down?
 If you don't have a 225e to store the settings, does the 250e recall
all data for the current settings, or do you have to reprogram it
every time you power up (or load the program from the 225e if you have
one)?
Sorry for this basic question ...
KKonkkrete
Re: [200e] 250e question
2008-08-20 by JB
This is something i know Ezra has been working on implementing in all
modules, but im not sure if the 250 has this feature yet. I would
recommend getting the 225e though, being able to switch presets is
very valuable if you plan to use the system live, its a great feature,
i use it all the time.
2008/8/20 kkonkkrete <kkonkkrete@yahoo.co.uk>:
> one)?
> Thanks,
> KKonkkrete
Re: 250e question
That's a shame.  I wanted to start with the following units in a
6-boat and get the 225e when I expand to a 12-unit system:
1 x 250e
2 x 261e
1 x 281e
1 x 292e
Perhaps I have to rethink this, as saving the sequence is a very basic
operation that I'll need all the time (don't want to *have* to start
from scratch every time I turn on).
Thanks for the quick reply.
> 2008/8/20 kkonkkrete <kkonkkrete@...>:
> > one)?
> > Thanks,
> > KKonkkrete
> > Yahoo! Groups Links
Re: 250e question
How does 2 x 4-boats work with the buses and power distribution?  It
seems like if I get 2 x 4-boats, I might as well just get a (half
empty) 12-cabinet, so that I don't have to ship the boats back
afterwards when I upgrade to a cabinet.
--- In 200e@yahoogroups.com, don hassler <dlh30039@...> wrote:
> You could go in similar route as me and start with a pair of 4
boats, then add the third when funds allow. Since I've added a 266e,
and fyi, it appears there may be possibility of Buchla producing
another batch of 259e waveform generators, if enough folks are
interested I think.
> Don
> --- On Wed, 8/20/08, kkonkkrete <kkonkkrete@...> wrote:
> > From: kkonkkrete <kkonkkrete@...>
> > Subject: [200e] Re: 250e question
> > To: 200e@yahoogroups.com
> > Date: Wednesday, August 20, 2008, 6:35 AM
> > units in a
> > 1 x 250e
> > 2 x 261e
> > 1 x 281e
> > 1 x 292e
> > very basic
> > to *have* to start
> > --- In 200e@yahoogroups.com, JB <ringmodulator@>
> > implementing in all
> > yet. I would
> > switch presets is
> > a great feature,
> > > 2008/8/20 kkonkkrete <kkonkkrete@>:
> > to reprogram it
> > > > one)?
> > > > Thanks,
> > > > KKonkkrete
> > > > Yahoo! Groups Links
Re: [200e] Re: 250e question
2008-08-20 by don hassler
You could go in similar route as me and start with a pair of 4 boats, then add the third when funds allow. Since I've added a 266e, and fyi, it appears there may be possibility of Buchla producing another batch of 259e waveform generators, if enough folks are interested I think.
Don
--- On Wed, 8/20/08, kkonkkrete <kkonkkrete@yahoo.co.uk> wrote:
> From: kkonkkrete <kkonkkrete@yahoo.co.uk>
> units in a
> 1 x 250e
> 2 x 261e
> 1 x 281e
> 1 x 292e
> very basic
> to *have* to start
> implementing in all
> yet. I would
> switch presets is
> a great feature,
> to reprogram it
> > > one)?
> > > Thanks,
> > > KKonkkrete
> > > Yahoo! Groups Links
2008-08-20 by ezra buchla
if you plan to ultimately have the 12 panel cabinet, that's true.
if you're not sure, or you don't particularly care about the folding
cabinet, you could always get a 3rd 4p boat later.
> interested I think.
>> Don
>> > units in a
>> > 1 x 250e
>> > 2 x 261e
>> > 1 x 281e
>> > 1 x 292e
>> > very basic
>> > to *have* to start
>> > implementing in all
>> > yet. I would
>> > switch presets is
>> > a great feature,
>> > to reprogram it
>> > > > one)?
>> > > > Thanks,
>> > > > KKonkkrete
>> > > > Yahoo! Groups Links
that's right. getting autonomous preset storage in the 250e is a
priority but it's proven difficult. next firmware rev.
fort now, you must use a 225.
>> one)?
>> Thanks,
>> KKonkkrete
>> Yahoo! Groups Links
Re: 250e question
OK, now here's something I don't understand: are the pots on the 250e
specifying the voltages at runtime, or are they just a 'convenience'
method for entering values into some internal memory?  What I am
getting at is the following: suppose I use the pots to make a very
basic CV sequence for output A with just the default values for
everything else.  If I then power cycle the unit without touching the
pots and press start, will the sequence still 'be there' (after all,
the pots haven't moved).  Or would I have to wiggle each one again to
're-enter' the value into the memory?
This makes me think of a more general problem with discrepancy between
pot positions and stored values in the 200e as a whole: how is the
conflict resolved?  If you touch a knob after loading a preset, does
the value jump to the new pot position, or is there a 'latch' mode
like on some other synths (not sure which is better / worse, I don't
really like either)?
Is there a way to force a module to use its front panel settings
rather than whatever is stored in patch memory (I can imagine, for
example, pressing and holding 'remote enable' for a few seconds, to
toggle between the front panel values and the stored values).
Sorry for all these questions, I just want to make sure I order
exactly what I need.  By the way, quantization doesn't really bother
me: many of my other analogue sequencers don't even have it. As long
as you can adjust the sequencer CV's finely enough to hit the sweet
spot, I don't care.
Thanks a lot!
down?
have
> >> one)?
> >> Thanks,
> >> KKonkkrete
> >> Yahoo! Groups Links
Re: 250e question
> you could say that the second case is true, in that there is a
> computer in there with realtime memory. in the 250e, it is
> continuously updating this realtime memory (and the cv output) based
> on the knob position of the *current stage,* or based on something
> else like an external cv input if it's in that mode.
OK, this makes sense, of course.  But as I only care about the voltage
as each stage is reached, this is a moot point: presumably for normal
function this updating must be pretty damn quick after the stage is
addressed.
> the current behavior of the 250e is that it's supposed to read the
> physical knob positions when it powers up, but it's slightly buggy
> because of a conflict with the interpolation algorithm (which i'll get
> to in a second) and because the knobs aren't all scanned at once but
> rather at each stage of the sequence (which allows each knob to be
> scanned at a much faster update rate). so it's tricky, and right now
> the accuracy at startup depends on the difference between the stored
> values and the phyiscal values. one of our programmers is working very
> hard on making it better. at the moment i'm afraid the best way to get
> consistent behavior is to use the thing in conjunction with a 225.
> it's somewhat of a trade-off, but i personally consider it more
> convenient than old drifty analog sequencers.
OK, but if the knobs haven't moved at all since I set the stored
values, the interpolated value at runtime will presumably be the same
as both the knob position and the stored value (if x=y and
z=ax+(1-a)y, where 0<a<=1, then z=x=y).  Or is there a resolution
issue here that I haven't thought of that could throw things off?
To be honest I don't really care about multiple presets: the only
reasons I would get a 225e would be (i) syncing to MIDI clock, (ii)
making use of MIDI performance interfaces, and (iii) remembering the
sequencer settings. From what you've said, I *think* I can still wait
with the 225 until I upgrade to the 12-cabinet next year.
> a behavior that i maybe like better is to have the 250e alwasy load
> preset zero at startup, so you can have some control over the
> "default" behavior, and to make it amenable to the autonomous preset
> storage behavior that we implemented in the 210, 291 and others. even
> this is kind of difficult because of the realtime updating that i
> mentioned before, but fixing it is a high priority.
Not sure I like the sound of that (for me, right now).  That would
REALLY force you to have a 225e.
> neither do we. the 259e was the first module in the series and it used
> a latch, but don has since designed a quite elegant algorithm to
> smoothly interpolate between the physical knob positions and the
> stored parameter values at all times. basically the knob range is
> rescaled until its position matches the stored position, at which
> point it resumes its default scaling with no perceivable transition.
> this is true for nrealy all of the knobs in the system.
Now that sounds cool.  Never encountered that before.  So let me get
this straight: suppose the stored value is 0 (min) and knob is at 10
(max), then when you turn the knob, nothing will happen until you hit
zero.  Whereas, if stored is at 5 (midpoint) and knob is at 10, when
you turn the knob, you'll start decreasing from 5 at a rate that is
constantly changing until (at some point), you 'catch up' and knob
position becomes absolute (rather than relative).  I guess the only
problem is if the knob is at 10 you can't increase above 5 without
going down a little first (in fact, do you have to pass through the 5
position to be able to go up from there?).  Have I got that right?  In
practice I'm sure it works well ...
> that's a nice idea. the remote enable button is already overloaded but
> it's a nice idea. currently you can make sure you are reading the full
> range of each knob by sweeping it between its extremes.
> forcing each module to re-scan its panel with a switch might be cool,
> but it also might be less useful than you think. the patch recall is
> really kind of magical, and all knobs always respond smoothly and
> pretty much as expected.
I can believe that.  On the other hand I use this function all the
time with my Creamware Minimax.
> > spot, I don't care.
> cool. accurate pitch is of course a crucial and difficult problem
> because of the incredible resolution of the ear in the frequency
> domain. the buchla solution has always been to allow arbitrary scaling
> of frequency modulators. this means that it is possible to trade range
> for accuracy at will, or vice versa. i think it is still a good system
> that works quite well, and has managed to accomodate a wide variety of
> technical limitations and tolerances in the last 35 years.
> i might as well freely admit that the 250e is not an analog sequencer,
> it has a digital brain and an analog-style interface layer. in some
> respects its character is noticeable, but in other respects it kind of
> transcends such discriminations with a truly freaky set of
> capabilities...
Oh I know it's not analogue.  Never made much sense to me to use
analogue for stored voltages anyway.  What I do care about is
directness of the interface, and being able to control it with CVs and
gates.
> > Thanks a lot!
> no prob
> -eb
in all
feature,
> > down?
recall
> > have
> >> >> one)?
> >> >> Thanks,
> >> >> KKonkkrete
> >> >> Yahoo! Groups Links
well, it's a little complicated...
What I am
> spot, I don't care.
capabilities...
> Thanks a lot!
no prob
-eb
> down?
> have
>> >> one)?
>> >> Thanks,
>> >> KKonkkrete
>> >> Yahoo! Groups Links
> addressed.
yep. to the outside world it looks quite smooth.
no, there's no resolution issue on that level. i think if the knobs
are at the same position as the preset, everything works as expected.
the problem is that there's no way to store presets without the 225;
it doesn't happen automatically; one reason is that flash memory has a
long but finite lifetime and it can't be written to every time a
parameter changes.
sorry, i wasn't clear enough. we have a new behavior in some modules
(the ones with a lot of complicated digital settings) where the remote
enable button functions as a "store preset zero" button if there is no
225e present in the system, and then preset zero is always loaded on
startup. it's not quite transparent but its much better than starting
from scratch all the time (i wanted this because i was using e.g. a
two-panel with 210 and 291 in performances...)
i think this behavior needs to be implemented in the 250e to make it
totally functional, in my opinion, at least for people like yourself
(and myself, sometimes) who don't want to have to use a 225 all the
time. but there's an obstacle because the preset recall behavior at
startup is buggy for pretty complicated reasons. this will get figured
out as soon as possible; but in all honesty that might mean a couple
months or more.
that's about right. obviously if the knob is at 10 you can't increase
it anyway, you have to "ratchet" down and back up, or just sweep it
back and forth to get the full range back. but in general, moving a
knob in one direction will give you an immediate parameter change in
that direction; way better than jumping around or having a
fustratingly non-responsive latched knob.
it's definitely a cool idea that i haven't thought of, and now it is
on my mind. we're trying to stabilize the feature set of the 200e
though (so we can start making other stuff!), so i dunno if you'll
actually see that. maybe it could be easily implemented as a global
menu item from the 225, but on the individual modules we have a lot of
feature ideas and precious little interface left.
>> > spot, I don't care.
>> capabilities...
> gates.
>> > Thanks a lot!
>> no prob
>> -eb
> in all
> feature,
>> > down?
> recall
>> > have
>> >> >> one)?
>> >> >> Thanks,
>> >> >> KKonkkrete
>> >> >> Yahoo! Groups Links
