200e
250e fun
250e fun
2008-09-09 by jon schatz
http://divisionbyzero.com/2008-09-03.mp3
thanks,
-jon
"There are no differences but differences of degree between different
degrees
of difference and no difference."
- James, William. "Subjective Effects of Nitrous Oxide." Mind. 1882;
Vol 7.
Re: [200e] 250e fun
2008-09-09 by Richard Lainhart
Great sounds - thanks!
Can you explain your basic patch?
Richard Lainhart
http://www.otownmedia.com
http://www.downloadplatform.com/richard_lainhart
http://www.vimeo.com/rlainhart
http://www.airglowmusic.com
Re: [200e] 250e fun
2008-09-09 by Dhymitruy Bouryiotis
yep that's fun -- reminiscent of african thumb piano
> thanks,
> -jon
> degrees
> Vol 7.
Re: [200e] 250e fun
thanks richard!
i took a picture here:
http://divisionbyzero.com/2008-09-03.jpg
it's kind of hard to remember exactly how i arrived there. this was
one patch; other than altering the 227e channel volumes i didn't do
anything but press record.
there was a basic 250e sequence, lots of looping, etc.
the first sound that comes in is the saw wave from the 259e mod osc
sequenced from a channel of the 250e and run through a 292 lpf.
the second sound is the 261e sequenced by the second 250e channel run
through a 292 lpg. the mod osc is controlling amplitude and (maybe)
pitch.
the third sound is the main 259e osc; morph is being modulated by the
mod osc.
the fourth sound is a 260e in continuous mode gated from the 250e.
there's a lot of randomness going on; the 266e is going _everywhere_,
especially on the 261e. i used the quantized random voltage to deliver
random gates which sometimes step the 250e here and there; there's
also a 281e lfo going into the 250e's clock to subtly alter the tempo.
other 281e envelopes are moving sounds in the stereo field (no quad on
this). i believe one 250e cv track is doing the same. i'm sure a lot
of other stuff that i'm forgetting, but following the wires in the
picture is really hard to do.
thanks,
-jon
degrees
Vol 7.
