On Apr 28, 2009, at 4:07 AM, amnesia wrote:
> is the 225e needed if you are buying the 222e?
> Will I need to use the 225e or will the 222e be fine without it...I am
> talking the MIDI side of things.
as far as i can tell, the 222e doesn't do anything with the midi
portion of the 225e.
you'll probably want a 225e or a 206e as a preset manager for your
setups since it takes some time to get your keyboard values entered in.
i don't know if the newest version of the 222e software has the
standalone preset functionality but v1 definitely doesn't so i lose
all my work when i power down unless i save with the 225e.
thanks,
-jon
"There are no differences but differences of degree between different
degrees
of difference and no difference."
- James, William. "Subjective Effects of Nitrous Oxide." Mind. 1882;
Vol 7.
