Re: 222e sustained tone
2011-02-18 by zaum
All the way counter-clockwise is the standard position for a gate on the Buchla or a VCA for that matter. Some budget VCAs eliminate the pot altogether so the normal state is the same as turning it all the way down. As an aside you can read stories about the Arp Odyssey which had a slider. Basically people would push it up, let sound through all the time and then claim it was broken. Why have that? Well I love it to mix without a 227e or test my connections without a CV signal. Practically it lets you adjust the response to voltages in , though on a typical VCA you have negative voltages in your system making VCA offset essential for bipolar CV, but that's not normal in a Buchla. For a Low Pass gate the really obvious need for this kind of configuration is the Low Pass capability. It's a filter and you need to adjust it. That gets me thinking, well then, why can't I adjust the Low Pass and Gate capabilities independently? But the reality is it doesn't work that way, though given you have at least 4 LPGs you hopefully have one to spare so you can do the LP and the Gate separately on 2 of them in series.
