Re: 4 powered boat rack mounting
2006-05-17 by alt-mode
Another opinion from the peanut gallery: I'm interfacing 200e with Serge/Cynthia/Modcan/Fenix/Milton and some older 200 series modules pretty well. I agree that you need to have separate 'pitch buses' for the oscillators and MIDI is probably best for the 200e oscillators. The 225e also provides some convenient outputs for MIDI controllers. I use an Encore Expressionist for the 1v/oct oscillators and a modified JKJ Electronics MIDI-CV converter for the older Buchla stuff. One thing I did that helps is to make sure everything is grounded together and then get a few banana to 1/8" cables. This allows you to quickly get the 1/8" audio signals out of the Buchla into the rest of the banana world and since everything is on a common ground, you don't have any problems with the missing ground connection on the adapter cables. I don't tend to mix different oscillators too much on the same sound so I don't have to worry about scaling issues very often but I do find the now discontinued Cynthia octal inverting attenuator, and the attenuators on several of the Modcan modules to be very helpful in general. Eric
> From: "Gary Chang" gchang@calarts.edu > Date: Mon May 15, 2006 9:44pm(PDT) > Subject: Re: 4 powered boat rack mounting > > Just another opinion from the peanut gallery, from someone who doesn't > have a 200e, but has some experience with older Buchla systems... > > Don't even try to interface/interconnect your Buchla system to other > systems - you will waste many years of your life...! > > The simplest way to get external pitches to the 200e is going to be > midi. A device, such as an Analog Systems AS300 cv to midi converter > will do the trick. It will convert your CVs and gate/trigger > information perfectly to the 200e's liking. And vise versa for going > the other way, back to the Frac synth. > > Years ago (1876!), at Calarts, I would bring my 9 panel Serge into the > electronic music studios at Calarts, in which a really large Buchla > system was the central system. To make a long story short, I found > myself spending all my time messing around with the processors, > contantly tweaking the rescaling of signal between the two. > > It's like having two really beautiful rooms, but you are spending all > of your time in the hallway, never really enjoying one or the other... > > Of course, that's just my opinion - I could be wrong! > > Gary > >
