210e -- audio signal phase reversal?
2008-04-26 by Matt Carpenter
Hi all, I was just wondering if the 210e allows phase reversal of the audio signal or if phase reversal is possible via other means, specifically for the purposes of feedback/feedforward experimentation. Thanks! Matt
2008-04-26 by mritenburg
I might be wrong, but I have always assumed that on the 227e, positions A, B, C, and D are 90 degrees out of phase from one another. So C is 180 degrees out of phase from A and D is 180 degrees out of phase from B. Matt --- In 200e@yahoogroups.com, "Matt Carpenter" <matfhew.carpenfer@...> wrote:
> > Hi all, > I was just wondering if the 210e allows phase reversal of the audio > signal or if phase reversal is possible via other means, specifically > for the purposes of feedback/feedforward experimentation. > Thanks! > Matt >
2008-04-28 by nicholas_kent
Doesn't make much sense to me (But I don't own any modules). The 227e is a quad channel device. In general no one defaults audio as far as I know to 90 degree phase shifts to do quad. All you will wind up with is more potential of cancellation in an acoustic space. And 90 degrees for that matter probably requires a pair of allpass filters to achieve. It's not something you can get without filters as far as I know compared to just inverting the polatity for 180 degrees (though filters could do that too). My guess is people are thinking along these lines because if you are mixing quad audio you might very well want to hit your VCAs with 90 degree quadrature of a *control voltage* in order to do "circular" pan effects. Or perhaps someone just wants to identify the speakers in numbers rather than ABCD if they represent a quad space --- In 200e@yahoogroups.com, "mritenburg" <mritenburg@...> wrote:
> > I might be wrong, but I have always assumed that on the 227e, positions > A, B, C, and D are 90 degrees out of phase from one another. So C is > 180 degrees out of phase from A and D is 180 degrees out of phase from > B. > > Matt > > > > --- In 200e@yahoogroups.com, "Matt Carpenter" <matfhew.carpenfer@> > wrote: > > > > Hi all, > > I was just wondering if the 210e allows phase reversal of the audio > > signal or if phase reversal is possible via other means, specifically > > for the purposes of feedback/feedforward experimentation. > > Thanks! > > Matt > > >
2008-04-28 by tmeade1974
I found this in the archives: http://launch.groups.yahoo.com/group/200e/message/104 "You can also phase shift the filtered signal using spacial dynamics in the 227e. B and C are 90 degrees out of phase from A and D is 180 degrees out of phase from A. Mix the filtered signal back to the original signal - voila, a phaser. Try it with 1 signal sent to all channels of the filter with each channel set to a different center frequency." I seem to remember another post concerning the same issue... maybe in regards to the 259e sine output???.... but I can't find it at the moment. I don't have a 227e so I cannot comment or test it out. -tom --- In 200e@yahoogroups.com, "nicholas_kent" <zaum@...> wrote:
> > Doesn't make much sense to me (But I don't own any modules). The 227e > is a quad channel device. In general no one defaults audio as far as I > know to 90 degree phase shifts to do quad. All you will wind up with > is more potential of cancellation in an acoustic space. And 90 > degrees for that matter probably requires a pair of allpass filters to > achieve. It's not something you can get without filters as far as I > know compared to just inverting the polatity for 180 degrees (though > filters could do that too). > > My guess is people are thinking along these lines because if you are > mixing quad audio you might very well want to hit your VCAs with 90 > degree quadrature of a *control voltage* in order to do "circular" pan > effects. Or perhaps someone just wants to identify the speakers in > numbers rather than ABCD if they represent a quad space > > > --- In 200e@yahoogroups.com, "mritenburg" <mritenburg@> wrote: > > > > I might be wrong, but I have always assumed that on the 227e, positions > > A, B, C, and D are 90 degrees out of phase from one another. So C is > > 180 degrees out of phase from A and D is 180 degrees out of phase from > > B. > > > > Matt > > > > > > > > --- In 200e@yahoogroups.com, "Matt Carpenter" <matfhew.carpenfer@> > > wrote: > > > > > > Hi all, > > > I was just wondering if the 210e allows phase reversal of the audio > > > signal or if phase reversal is possible via other means, specifically > > > for the purposes of feedback/feedforward experimentation. > > > Thanks! > > > Matt > > > > > >
2008-04-28 by ezra buchla
there is some confusion of terms. the paragraph below should read, "the AMPLITUDES of B and C..." etc. i don't think the conclusion is right. panning stuff around the quad outputs doesn't produce delay, which is the essential component of phasers, etc. fortunately there are sweet sweet phasers and filters in the system already. -eb On Mon, Apr 28, 2008 at 12:54 PM, tmeade1974 <tmeade1974@yahoo.com> wrote: > I found this in the archives: > http://launch.groups.yahoo.com/group/200e/message/104 > > "You can also phase shift the filtered signal using spacial dynamics in > the 227e. B and C are 90 degrees out of phase from A and D is 180 > degrees out of phase from A. Mix the filtered signal back to the > original signal - voila, a phaser. Try it with 1 signal sent to all > channels of the filter with each channel set to a different center > frequency." > > I seem to remember another post concerning the same issue... maybe in > regards to the > 259e sine output???.... but I can't find it at the moment. I don't have a > 227e so I cannot > comment or test it out. > > -tom > > > --- In 200e@yahoogroups.com <200e%40yahoogroups.com>, "nicholas_kent" > <zaum@...> wrote: > > > > Doesn't make much sense to me (But I don't own any modules). The 227e > > is a quad channel device. In general no one defaults audio as far as I > > know to 90 degree phase shifts to do quad. All you will wind up with > > is more potential of cancellation in an acoustic space. And 90 > > degrees for that matter probably requires a pair of allpass filters to > > achieve. It's not something you can get without filters as far as I > > know compared to just inverting the polatity for 180 degrees (though > > filters could do that too). > > > > My guess is people are thinking along these lines because if you are > > mixing quad audio you might very well want to hit your VCAs with 90 > > degree quadrature of a *control voltage* in order to do "circular" pan > > effects. Or perhaps someone just wants to identify the speakers in > > numbers rather than ABCD if they represent a quad space > > > > > > --- In 200e@yahoogroups.com <200e%40yahoogroups.com>, "mritenburg" > <mritenburg@> wrote: > > > > > > I might be wrong, but I have always assumed that on the 227e, > positions > > > A, B, C, and D are 90 degrees out of phase from one another. So C is > > > 180 degrees out of phase from A and D is 180 degrees out of phase from > > > > B. > > > > > > Matt > > > > > > > > > > > > --- In 200e@yahoogroups.com <200e%40yahoogroups.com>, "Matt Carpenter" > <matfhew.carpenfer@> > > > wrote: > > > > > > > > Hi all, > > > > I was just wondering if the 210e allows phase reversal of the audio > > > > signal or if phase reversal is possible via other means, > specifically > > > > for the purposes of feedback/feedforward experimentation. > > > > Thanks! > > > > Matt > > > > > > > > > > > > [Non-text portions of this message have been removed]
