50g group photo
50g
Making a square wave on the HP48GII
2014-06-30 by willowvst@...
I am making a model of a frequency mixer on the HP48GII. I need to make a square wave as part of this.
The way I thought I would do it was to make a cosine wave and then use the SIGN function to give me a +1 when it's positive and a -1 when it's negative. I seem to get a line at +1 not the expected result.
The formula I have in Plot is 'C1(t)= SIGN(cos(2*(pi)*F1*t))'.
t is the independent variable.
Anyone know why it doesn't work?
Ed
Re: [50g] Making a square wave on the HP48GII
2014-07-01 by Don Hart
First some FYI...
cos should be COS. Upper/lower case matters, including the variables (t)
You don't really need 'C1(t)='. You can just use the righthand side by itself.
Use X for the independent var instead of 't', unless you change it in the settings.
Now, I'm not sure what all your equation does (F1 ?) so I simplified and the following works:
%%HP: T(3)A(R)F(.);
'SIGN(COS(2*\pi*X))'
or
%%HP: T(3)A(R)F(.);
'C1(X)=SIGN(COS(2*\pi*X))'
ASCII shall receive, Hollerith and get it quicker
On Mon, 6/30/14, willowvst@... [50g] <50g@yahoogroups.com> wrote:
 Subject: [50g] Making a square wave on the HP48GII
 To: 50g@yahoogroups.com
 Date: Monday, June 30, 2014, 5:25 AM
 Ed
2014-07-25 by willowvst@...
Thanks Ron,
I will try your suggestion.
I never got the sign function working (when I was trying this mixer) but I did get the mixer working!
best wishes,
Ed
