equations on 50g
2007-09-12 by silverbabe_deluxe
hey.. how do I find a,b and c in f(x)=ax^2+bx+c when I know the graph pass through point (1,3) (2,8) and (-2,12)
2007-09-12 by Alexander Cutshall
hey..
and (-2,12)
2007-09-12 by sebasmagri
I think that this little program can help you... it`s from a
minichallenge realized in a latin american web page...
As arguments you have to put the three points in lists in the
following way:
7:
6:
5:
4:
3: {x1 y1}
2: {x2 y2}
1: {x3 y3}
It`s the source code...
\<< + + EVAL SWAP DUP
SQ 1 \->V3 4 ROLL DUP
SQ 1 \->V3 6 ROLL DUP
SQ 1 \->V3 SWAP ROT 3
ROW\-> INV 4 ROLLD
\->V3 * -3 FS?C 'Y'
ROT V\-> SWAP 'X^2' *
ROT 'X' * + SWAP +
= SWAP
\<< -3 SF
\>> IFT
Greetings from Venezuela...2007-10-02 by Richard Fellows
I found it more fun to just pull out my 50g, enter a [3 8 12] vector for the right-side constants, use the MTRW to construct a 3X3 matrix for the left side constants, and then "divide" it into the vector to get [2 -1 3] as the values for A, B, and C. Just for grins, I ran it through the linear system solver too and, amazingly, got the same answer :-) Dick --- In 50g@yahoogroups.com, Alexander Cutshall <alexc@...> wrote: > > It's basically solve for three variables in a three equation system > problem. > > Plug point one into f(x) and you get: > > 3=a(1)^2+1b+c > > Simplify and stick the constant on the right. > > a+b+c=3 > > Point two: > > 8=a(2)^2+2b+c > > again, simplify > > 4a+2b+c=8 > > Third: > > 12=a(-2)^2-2b+c > is > 4a-2b+c=12 > > Now, you have options. Solve by Cramer's rule, substitution, or > elimination. The system ends up being: > > a + b + c = 3 > 4a + 2b + c = 8 > 4a - 2b + c =12 > > (hopefully that stacks neatly in your email) > > I'd use elimination, as it's much less messy. If you're interested in > the steps for that, E-Mail me off list. > > Cheers, > Alex > > On Sep 12, 2007, at 11:49 AM, silverbabe_deluxe wrote: > > hey.. > > > > how do I find a,b and c in > > f(x)=ax^2+bx+c when I know the graph pass through point (1,3) (2,8)
> > and (-2,12) > > > > > ------ > "I love America more than any other country in this world, and, > exactly for this reason, I insist on the right to criticize her > perpetually." > - James Baldwin > > Alexander Cutshall > alexc@... >
2007-10-28 by Juan C.
To solve your problem, first put your calculator in RPN mode and soft menu (flag 117 set). first enter a vector with the values of y. (wherever you see a space pres the [SPC] key and notice LS Left Shift and RS Right Shift.) LS[]3 8 12 ENTER enter a vector with X^2 X and 1 and duplicate it. LS[] 'X^2' 'X' 1 ENTER ENTER enter X=1 and substitute this value in the vector. 'X=1' ENTER RS ALG NXT SUBST swap the contents in level 1 and level 2, duplicate the vector in level 1, enter X=2 and substitute this value in the vector. Press the right arrow of the cursor key to swap. ENTER 'X=2' ENTER SUBST swap one last time, enter X=-2 and substitute this value in the vector. Press the right arrow of the cursor key to swap. 'X=-2' ENTER SUBST At this point you have four vectors in the stack, the last three are rows of the matrix for the system. Let's form that matrix. 3 RS MTH MATRX ROW ROW-> to solve this system just press the divided by key, here we represent it by / / the result is the vector [2 -1 2] a=2, b=-1 and c=2 you can check the solution with the function PEVAL (Polynomial EVALuation) you need the vector of coeficients in level 2 in this case [2 -1 2] and the value of X (like 1) in level 1 and PEVAL find the value of f(x).
