50g group photo
50g
devide key
devide key
2008-04-18 by riaanbarnard2000
Hi
Please help. During one of many discoveries of my new Hp50g I did
something to alter the devide key. When I type 50/3 the curser does not
move after pressing the devide key. What did I do. Should i perform a
reset and if so how?
Thanks
Riaan
Re: [50g] devide key
2008-04-18 by Alan Golightly
Did you use this sequence?:
50 enter
3 divide?
try pressing cancel, which is the ON key
----- Original Message ----
To: 50g@yahoogroups.com
Sent: Friday, April 18, 2008 1:53:29 AM
Subject: [50g] devide key
Hi
Thanks
Riaan
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Re: devide key
2008-04-19 by riaanbarnard2000
Hi
No. I am set up in ALG mode. W hen I type the +(or - or *) key the
arrow moves one position to the right. When I type the / key it stays
on top of / sign just entered.
Riaan
Re: [50g] Re: devide key
2008-04-19 by Don Hart
And what happens when you enter the digit after the /?
Is the result of the calculation correct?
Also, I suggest you try the RPN mode. Once you get
used to it, I think you'll like it better.
--- riaanbarnard2000 <riaan@...> wrote:
> Hi
> or *) key the
> the / key it stays
> Regards
> Riaan
2008-04-19 by Alan Golightly
I put mine in ALG mode, and seems to work fine.
50 / 3 enter
or 50 * 3 enter
both work correctly.
Sounds like a strange problem, sorry I am pretty new to the HP50G
Sent: Saturday, April 19, 2008 1:28:34 AM
Subject: [50g] Re: devide key
Hi
Riaan
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
2008-04-20 by Nancy Von Essen
Hi Riaan Ed here. To reset the 50G, push one end of a small paper clip or similar tool into the little hole on the back of the 50G that is located to the left and just down a bit from the serial number. push straight in and hold for a second or so. When you release, turn the 50G over and watch the display to ensure that this worked. You should see a logo come up.
Uou said that the cursor didn't move. Does the cursor alternately blink with the divide symbol?
Switch to RPN definitely using the MODE key. There's a lot to learn. Ed
riaanbarnard2000 wrote:
Hi
Thanks
Riaan
