50g group photo
50g
Purge all single letter variables A through Z?
2008-08-10 by arthurford4142
Is there a quick and easy way to purge these variables? The Filer is
easy but it's not quick to use. My goal is to purge A - Z just prior
to a new calculation. Perhaps a short program? (Hit VAR, then the
appropriate soft menu key, then do the calculation.) Here's my scenario:
Mode is set to HEADER: 2. The 2nd line displays {HOME TEST}, where
TEST is a subdirectory of HOME. I want to purge A - Z in both TEST and
HOME by hitting VAR and the appropriate soft menu key. My programming
skills are at the novice level, limited to simple conversions like
Centigrade to Fahrenheit.
Thanks, Arthur
RE: [50g] Purge all single letter variables A through Z?
2008-08-10 by Jeremy Hawdon
Hi Arthur,
The following program should do the job, provided that your directory list
is a path for the final directory.
\<< WHILE DUP SIZE
      REPEAT DUP HEAD EVAL TAIL 65 90
             FOR k CHR  "'" + OBJ\--> PURGE
             NEXT
     END DROP
Checksum is #5C70h. Store in home under a suitable name.
Regards, Jeremy
  _____
From: 50g@yahoogroups.com [mailto:50g@yahoogroups.com] On Behalf Of
arthurford4142
Sent: 10 August 2008 10:37
To: 50g@yahoogroups.com
Subject: [50g] Purge all single letter variables A through Z?
Thanks, Arthur
Re: Purge all single letter variables A through Z?
2008-08-12 by arthurford4142
Thanks Jeremy,
Still struggling with this. Just noticed a tick mark between the
quotation marks; I swear I didn't see that before this reply. Not sure
about the "-->", if right shift 0 doesn't work I'll try the right
shift CHARS one. I'm familiar with checksum, but have not run across
it in relation to the 50g. I'm totally stumped on that one.
Thanks, Arthur
--- In 50g@yahoogroups.com, "Jeremy Hawdon" <jeremy.hawdon@...> wrote:
> Hi Arthur,
directory list
> \<< WHILE DUP SIZE
>              NEXT
>      END DROP
> Regards, Jeremy
>   _____
> arthurford4142
scenario:
> Thanks, Arthur
RE: [50g] Re: Purge all single letter variables A through Z?
2008-08-12 by Jeremy Hawdon
Hi Arthur,
Right shift 0 should work (if you are in alpha mode) bout OBJ\--> is a
command found in the TYPE menu (left shift PRG TYPE). The checksum is
produced if you put a copy of the program on the stack and press left shift
PROG MEM BYTES, it is useful for checking that you have entered the program
correctly.
If you always wish to call this program to clear all single letter variables
'visible' from a sub-directory, you could store it under a suitable name in
home and add PATH as the first instruction in the program. Then when it is
called from the sub-directory(perhaps using the custom menu) there will be
no need to put anything on the stack.
Jeremy
  _____
arthurford4142
Sent: 12 August 2008 09:52
Subject: [50g] Re: Purge all single letter variables A through Z?
Thanks Jeremy,
Thanks, Arthur
--- In 50g@yahoogroups. <mailto:50g%40yahoogroups.com> com, "Jeremy Hawdon"
> Hi Arthur,
directory list
> \<< WHILE DUP SIZE
> NEXT
> END DROP
> Regards, Jeremy
> _____
> From: 50g@yahoogroups. <mailto:50g%40yahoogroups.com> com
[mailto:50g@yahoogroups. <mailto:50g%40yahoogroups.com> com] On Behalf Of
> arthurford4142
> To: 50g@yahoogroups. <mailto:50g%40yahoogroups.com> com
scenario:
> Thanks, Arthur
