50g group photo
50g
adding caps to equations?
2009-03-05 by tony
Does anyone know how to add a capacitor or two to an exsisting formula?
I tried hooking my hp50 to my computer but it doesn't seem to work,I thought that maybe I could alter the formula that way. Is that possible?
Thanks
Tony
Re: [50g] adding caps to equations?
2009-03-06 by Don Hart
I can't say I'll have an answer for you but you can try to be more specific...like what program are you using?
What doesn't work when you connect the hp50 to the pc? Are you not able to do anything, transfer files for instance? Or, are you just not able to alter a formula thru the pc?
--- On Thu, 3/5/09, tony <anthonypicariello@...> wrote:
> From: tony <anthonypicariello@...>
> Subject: [50g] adding caps to equations?
> To: 50g@yahoogroups.com
> Date: Thursday, March 5, 2009, 10:27 AM
> exsisting formula?
> Thanks
> Tony
2009-03-06 by jatspic
Hi Don,
I am using the formula that was already in the calculator(electricity formulas).
I am using the connectivity software that also came with my HP50g. I really don't have a clue as to how to use it, I just assumed that I could modify the electricity formulas ie: adding more capacitors to the series parallel capacitor formula. How do I modify the formulas and do I store them on my SD card or computer? As to transfering files I have not tried this, the little bit of info I recieved said something about changing from kermit to xserve,not really sure about those either. Sorry for being so non specific,this is a whole new realm for me. thank you in advance for any help you can give me.
Tony
--- On Fri, 3/6/09, Don Hart wrote:
Subject: Re: [50g] adding caps to equations?
Date: Friday, March 6, 2009, 1:43 AM
--- On Thu, 3/5/09, tony <anthonypicariello@ verizon.net> wrote:
> From: tony <anthonypicariello@ verizon.net>
> To: 50g@yahoogroups. com
> exsisting formula?
>; I tried hooking my hp50 to my computer but it doesn't
> Thanks
> Tony
Re: adding caps to equations?
2009-03-06 by Tim Wessman
Having used the equation library a zillion times, while I initially thought I would need to modify stuff to get done what I wanted, I quickly found that to not be the case. You can easily use the tools to get the job done on you understand how they've set it up.
If you'd really like to modify it though, it is very easy to do. Select the equation you'd like, hit SOLVE, then when you exit, go into N.SLV, SOLVE EQUATION, and there you have your equation (which is stored into the variable name EQ). You can then edit to your hearts content and save it as something else.
TW
Re: [50g] Re: adding caps to equations?
thank you,I will give it a try
Tony
--- On Fri, 3/6/09, Tim Wessman wrote:
Subject: [50g] Re: adding caps to equations?
Date: Friday, March 6, 2009, 11:15 AM
TW
