50g group photo
50g
Help With The Map Function
2009-06-06 by rickwendel763242
I would like to take a list saved as a variable and a function saved as a variable and use them with the MAP function to calculate a set of answers to the function, based on the list.  Can anybody show me how to do that in RPN mode?
Re: Help With The Map Function
2009-06-06 by Juan C.
You have to recall the function to the stack before you perform the command MAP. Let's say you have a list saved as MYLST and a function saves as MYFCT, then from the VAR menu press MYLST to put the list in the stack then then 'MYFCT' enclosed with single quotation marks, then press [left-shift][STO] to RCL the content of MYFCT, now you are ready to use MAP.
