The Yamaha AN1x Synthesizer mailing list group photo
Index last updated: 2026-04-28 22:40 UTC
re: Headphones
re: Headphones
2006-10-10 by spaceanimals
It's not normal. Plug the phones into the headphone jack (the one
that's all the way over) and you should hear lovely stereo.
Jimmy
Re: Headphones
2006-10-10 by an1x_joe
Thank you Jimmy,
but i plugged the phones into the headphone and only can heard by the
left and  If i plug the phones into the output right the sound listens
by the left headphone too.
Is my an1x damaged?.
--- In AN1x-list@yahoogroups.com, "spaceanimals" <rainbowjimmy@...>
> Jimmy
Re: [AN1x] Re: Headphones
2006-10-10 by Jeff
Hi Joe !
first : try another headphones set . If the stereo sound is back it's
either the headphones or the headphones male jack .
If not :
2 : try to plug your synth in a stereo amp* with a good pair of cables
in the 2 output jacks and listen ...  If you have both channel it's the
female headphone jack (on the back of the AN1X) that's faulty . These
jack are often a cause of troubles , less likely than with guitars but
.... If not
3: edit your patch and check if the pan setting is not "full right" or
"full left" .
And if you have no chance the output amp has one channel out .... it
could be only a loose solder, a broken wire or ... You have to open the
synth to check these points. If you have no basic electronic knowledge,
ask your friend or your brother or your neighbour or .. somebody else
who has .
As the AN1X is not a real analog instrument it is far more reliable than
old time synths and less prone to failures . But you can have some
contacts problems with the jacks or the internal connectors .
J.F.
*It's line level outputs so you can plug them in the "aux" input of your
HiFi amp or any line input (mixer, instrument amp ...) . Take care when
using mike or guitar inputs with high sensitivity if you don't want to
burn something in the amp...
an1x_joe a \ufffdcrit :
>Thank you Jimmy,
>>Jimmy
>Community email addresses:
>  Post message: AN1x-list@yahoogroups.com
>  Subscribe:    AN1x-list-subscribe@yahoogroups.com
>  Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>  List owner:   AN1x-list-owner@yahoogroups.com
>Shortcut URL to this page:
>   http://groups.yahoo.com/group/AN1x-list
>The AN1x Control Synthesizer FAQ::
>  http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
>Yahoo! Groups Links
>avast! Antivirus: message Entrant propre.
>Base de donn\ufffdes des virus (VPS): 0641-0, 10/10/2006
>Test du: 10/10/2006 19:03:04
>avast! - copyright (c) 2000-2006 ALWIL Software.
>http://www.avast.com
avast! Antivirus: message Sortant propre.
Test du: 10/10/2006 19:24:17
