The Yamaha AN1x Synthesizer mailing list group photo
Index last updated: 2026-04-28 22:40 UTC
DC in
DC in
2010-03-28 by jadestarbaby
I am wondering whether anyone knows whether the DC in for the AN1x ha a positive tip or negative tip. It does not say on the outside of the AN1x and i also could not find this info in the manual. Any help would be appreciated.
Robert H
Re: [AN1x] DC in
2010-03-29 by Summa
It's printed on the DC-Adapter: 12V/700mA, positive tip...
On 28 Mar 2010 at 20:36, jadestarbaby wrote:
> Hi,
> Robert H
> Community email addresses:
>   Post message: AN1x-list@yahoogroups.com
>   Subscribe:    AN1x-list-subscribe@yahoogroups.com
>   Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>   List owner:   AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
>    http://groups.yahoo.com/group/AN1x-list
> The AN1x Control Synthesizer FAQ::
>   http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
CZ/VZ 		mailing list	: http://groups.yahoo.com/group/CZsynth
FMHeaven	mailing list	: http://groups.yahoo.com/group/fmheaven/
FS1R		mailing list	: http://groups.yahoo.com/group/fs1r/
Vokator		mailing list	: http://groups.yahoo.com/group/vokator
FM-Synthesis	mailing list         : http://groups.yahoo.com/group/fm-
synthesis/
http://www.summasounds.de/
Re: DC in
2010-03-29 by Bim
12v 700mA center positive
As you probably have heard, not all power supplies are filtered and can cause your instrument to hum thru the outputs. Use of only Yamaha power supplies is highly recommended.....
--- In AN1x-list@yahoogroups.com, "jadestarbaby" <jadestarbaby@...> wrote:
> Hi,
> Robert H
Re: [AN1x] DC in
2010-03-29 by Jeff
The stock power supply is rated at 12V DC- 700 mA , positive tip.
If you use another one, 700 mA should be considered as a minimum, but
don't exceed the voltage rating and change the plug for the right type.
Similar supplies (and the right connector) can be found in electronics
shops, supermarkets, computer shops...
Cheers.
J.F.
jadestarbaby a \ufffdcrit :
> Hi,
> be appreciated.
> Robert H
Re: [AN1x] general power supply question
2010-03-31 by audiomad99@aol.com
hi,...does anyone know (on a wall wart type power supply ) regarding the 2 wires coming from the psu whether the black wire or the other wire that has a white line printed on it is the + or - line ??
i'm splicing a psu plug, to power up an eq module.
thanks ahead of time
To: AN1x-list@yahoogroups.com
Sent: Mon, Mar 29, 2010 1:24 pm
Subject: Re: [AN1x] DC in
Cheers.
J.F.
jadestarbaby a écrit :
> Hi,
> be appreciated.
> Robert H
Yahoo! Groups Links
2010-03-31 by Bim
9/10 times the wire with the white on it is positive, but to be absolutely certain you need to pull out your DVM (digital voltmeter), set it for DC voltage (if it was AC it wouldn't matter which was what) and test it and see.
If you dont have a DVM (which is an absolute necessity in working with anything electronic from cords to fuses to power supplies), you need to have one. Sears has a really nice autoranging DVM for maybe $30 although you can pick up a decent one at almost any hardware store...
> From: Jeff <jf.serviere@...>
> Cheers.
> J.F.
> > Hi,
> > be appreciated.
> > Robert H
2010-03-31 by Jeff
The "non black" wire is more likely the "+".
To be sure take some multimeter (basic models can be found in any
hardware - electronics store for quite nothing) and check.
You might find that the measured voltage is higher than the rated
voltage : nothing wrong, your supply is not regulated, and being
unloaded voltage rises. A regulated PSU gives a constant voltage
relatively independant of the load, but they're not so common, most of
the time the regulation part is located in the synth, sound module,
effect box etc...
Cheers.
J.F.
audiomad99@... a �crit :
> From: Jeff <jf.serviere@... <mailto:jf.serviere%40wanadoo.fr>>
> To: AN1x-list@yahoogroups.com <mailto:AN1x-list%40yahoogroups.com>
> Cheers.
> J.F.
> jadestarbaby a �crit :
> > Hi,
> > be appreciated.
> > Robert H
> <mailto:AN1x-list-subscribe%40yahoogroups.com>
> <mailto:AN1x-list-unsubscribe%40yahoogroups.com>
> <mailto:AN1x-list-owner%40yahoogroups.com>
> <http://groups.yahoo.com/group/AN1x-list>
> <http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm>
2010-04-01 by audiomad99@aol.com
awesome idea!! with the dvm,....
thanks soooo much
Leo
Sent: Wed, Mar 31, 2010 5:24 pm
Subject: Re: [AN1x] general power supply question
> Cheers.
> J.F.
> > Hi,
> > be appreciated.
> > Robert H
