Hi all: is it possible to insert a PLG150-DX into a AN200?
2012-06-08 by cristoforcolombo
Index last updated: 2026-04-28 22:40 UTC
Hi all, I'm new here - thank you for your archive and tips - and even if I made a quick search around I didn't find anything about this question: since An200 and Dx200 share the same parts (apart from plugins) do you think is possible to insert a PLG150-DX into a AN200 and or viceversa? Does anyone know for sure if this is going to work ornot? cheers Lucio
2012-06-09 by twobeelandscape
Hi Lucio AN200 owner here. That's an interesting question, and I don't know the answer for sure. However, I checked out screenshots of the AN200 and DX200 side-by-side. The knobs and buttons make them look like identical twins, apart from the VCO sections: AN200 VCO1: wave select button with 5 leds - saw, pulse, mix, vari, mlt saw DX200 Algorithm button (no leds, but the 32 possible algorithms must be shown on the data display of a DX200, don't see how an AN200 could do that) AN200 Sync: mode button with 3 leds - off, vco1 m>s, vco2>1 DX200 Modulator: select button with 4 leds - 3, 2, 1, all AN200 VCO2: wave button with 5 leds - saw, pulse, mix, tri, sine DX200 Noise Osc: Type button with 5 leds - white, up ,down, pitch, vari Other small differences: AN200 knobs VCO1/2 and Sync Pitch replaced by Harmonic and Decay on the DX200. So, on the hardware side, it is likely that you could fit the PLG150-DX into the AN200, and probably get a noise out if you played midi notes in, but you would be unlikely to be able to edit any of the parameters above. There is a further complication in that the PLG150-AN and PLG150-DX have different device IDs for receiving MIDI system exclusive data (01011100 5CH and 01011100 5CH respectively). So if the AN200 hardware host assumes it is hosting a PLG150-AN, then it will presumably send sysex messages from its knobs and buttons for that device, not for the PLG150-DX. You might be able to send appropriate PLG150-DX sysex messages from an external device (eg a computer to AN2000 MIDI in socket) which would be passed to the PLG150-DX card, but that would rather defeat the object of putting the card in a nice knobby box like the AN200. If you have access to a PLG150-DX card, probably best to try hosting it in one of the devices intened to take any of the PLG cards, eg CS6x, CS6R, SW1000XG, MU100, MU100R, MU128, S80, Motif, maybe others? Sorry that is not a definitive yes/no answer, and sorry it probably isn't the answer you were looking for :-) Bill --- In AN1x-list@yahoogroups.com, "cristoforcolombo" <sharm.band@...> wrote: > > Hi all, I'm new here - thank you for your archive and tips - and even if I made a quick search around I didn't find anything about this question: since An200 and Dx200 share the same parts (apart from plugins) do you think is possible to insert a PLG150-DX into a AN200 and or viceversa? Does anyone know for sure if this is going to work ornot? > cheers > Lucio > [Non-text portions of this message have been removed]
Typo error, the PLG150-DX device ID should have been 01100010 62H. Anyway, the important thing is that it is different to the PLG150-AN. Bill --- In AN1x-list@yahoogroups.com, "twobeelandscape" <bill@...> wrote:
> > There is a further complication in that the PLG150-AN and PLG150-DX have > different device IDs for receiving MIDI system exclusive data (01011100 > 5CH and 01011100 5CH respectively).
2012-06-09 by marcus gaudio
ok so it's possible or not? thanks ________________________________ Da: twobeelandscape <bill@...> A: AN1x-list@yahoogroups.com Inviato: Sabato 9 Giugno 2012 17:58 Oggetto: [AN1x] Re: Hi all: is it possible to insert a PLG150-DX into a AN200? Typo error, the PLG150-DX device ID should have been 01100010 62H. Anyway, the important thing is that it is different to the PLG150-AN. Bill --- In AN1x-list@yahoogroups.com, "twobeelandscape" <bill@...> wrote: > > There is a further complication in that the PLG150-AN and PLG150-DX have > different device IDs for receiving MIDI system exclusive data (01011100 > 5CH and 01011100 5CH respectively). [Non-text portions of this message have been removed]
2012-06-10 by jammie
no one knows as no one has tried it but i would think that theres an os eprom that controls it and has the functions of each board to control the front panel features and also the sysex implementation i would get yourself a cheap module that allows 2 cards
To: AN1x-list@yahoogroups.com
Sent: Saturday, June 09, 2012 10:36 PM
Subject: Re: [AN1x] Re: Hi all: is it possible to insert a PLG150-DX into a AN200?
ok
thanks
Da: twobeelandscape <bill@2bconsultancy.co.uk>
Bill
[Non-text portions of this message have been removed]2012-06-10 by twobeelandscape
Quote from my first post: "So, on the hardware side, it is likely that you could fit the PLG150-DX into the AN200, and probably get a noise out if you played midi notes in, but you would be unlikely to be able to edit any of the parameters above." --- In AN1x-list@yahoogroups.com, marcus gaudio <sucramgaudio@...> wrote:
> > ok > so it's possible or not? > thanks > >
2012-06-11 by cristoforcolombo
Well, thank you Bill and Jammie. I'm asking this prior to swap dx and An plg's I got. Well, I have a Motif Rack classic, also, with a Dx and Vl plg's. And I would install the Dx plg into the AN200 and the 150An into the Motif. Anyway, is there any danger int swapping cards? Lucio from the An200--- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@...> wrote:
> > no one knows as no one has tried it > > but i would think that theres an os eprom that controls it and has the functions of each board to control the front panel features > > and also the sysex implementation > > i would get yourself a cheap module that allows 2 cards > ----- Original Message ----- > From: marcus gaudio > To: AN1x-list@yahoogroups.com > Sent: Saturday, June 09, 2012 10:36 PM > Subject: Re: [AN1x] Re: Hi all: is it possible to insert a PLG150-DX into a AN200? > > > > ok > so it's possible or not? > thanks > > ________________________________ > Da: twobeelandscape <bill@...> > A: AN1x-list@yahoogroups.com > Inviato: Sabato 9 Giugno 2012 17:58 > Oggetto: [AN1x] Re: Hi all: is it possible to insert a PLG150-DX into a AN200? > > > Typo error, the PLG150-DX device ID should have been 01100010 62H. Anyway, the important thing is that it is different to the PLG150-AN. > > Bill > > --- In AN1x-list@yahoogroups.com, "twobeelandscape" <bill@> wrote: > > > > There is a further complication in that the PLG150-AN and PLG150-DX have > > different device IDs for receiving MIDI system exclusive data (01011100 > > 5CH and 01011100 5CH respectively). > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] >
2012-06-12 by twobeelandscape
Lucio >Anyway, is there any danger int swapping cards? Probably the biggest danger is physically damaging the cards when removing/inserting. I have read elsewhere that they can be difficult to remove due to locking tabs - not tried it myself. There is unlikely to be any danger of the boards being electrically incompatible as they will all have the same contact system. However, if you have a functional AN200 containing a PLG150-AN, and a Motif Rack containing a PLG100-DX and VL, it's not clear what is the benefit of swapping boards around to get a non-functional (non-editable, non-saleable) AN200 with DX card, and Motif with AN and VL. What are you trying to achieve? Bill --- In AN1x-list@yahoogroups.com, "cristoforcolombo" <sharm.band@...> wrote:
> > Well, thank you Bill and Jammie. I'm asking this prior to swap dx and An plg's I got. Well, I have a Motif Rack classic, also, with a Dx and Vl plg's. And I would install the Dx plg into the AN200 and the 150An into the Motif. Anyway, is there any danger int swapping cards? > Lucio > > > from the An200--- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@> wrote: > > > > no one knows as no one has tried it > > > > but i would think that theres an os eprom that controls it and has the functions of each board to control the front panel features > > > > and also the sysex implementation > > > > i would get yourself a cheap module that allows 2 cards > > ----- Original Message ----- > > From: marcus gaudio > > To: AN1x-list@yahoogroups.com > > Sent: Saturday, June 09, 2012 10:36 PM > > Subject: Re: [AN1x] Re: Hi all: is it possible to insert a PLG150-DX into a AN200? > > > > > > > > ok > > so it's possible or not? > > thanks > > > > ________________________________ > > Da: twobeelandscape <bill@> > > A: AN1x-list@yahoogroups.com > > Inviato: Sabato 9 Giugno 2012 17:58 > > Oggetto: [AN1x] Re: Hi all: is it possible to insert a PLG150-DX into a AN200? > > > > > > Typo error, the PLG150-DX device ID should have been 01100010 62H. Anyway, the important thing is that it is different to the PLG150-AN. > > > > Bill > > > > --- In AN1x-list@yahoogroups.com, "twobeelandscape" <bill@> wrote: > > > > > > There is a further complication in that the PLG150-AN and PLG150-DX have > > > different device IDs for receiving MIDI system exclusive data (01011100 > > > 5CH and 01011100 5CH respectively). > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > >
2012-06-21 by cristoforcolombo
Bill, I forgot to mention I also have a Yamaha Fs1R so the Plg-Dx is less useful to me (when plugged into the Motif). Another plus, should be the An-plg hosted into the Motif because of the fx section and overall better editability (I hope). --- In AN1x-list@yahoogroups.com, "twobeelandscape" <bill@...> wrote:
> > Lucio > >Anyway, is there any danger int swapping cards? > Probably the biggest danger is physically damaging the cards when removing/inserting. I have read elsewhere that they can be difficult to remove due to locking tabs - not tried it myself. There is unlikely to be any danger of the boards being electrically incompatible as they will all have the same contact system. > > However, if you have a functional AN200 containing a PLG150-AN, and a Motif Rack containing a PLG100-DX and VL, it's not clear what is the benefit of swapping boards around to get a non-functional (non-editable, non-saleable) AN200 with DX card, and Motif with AN and VL. What are you trying to achieve? > > Bill > > > --- In AN1x-list@yahoogroups.com, "cristoforcolombo" <sharm.band@> wrote: > > > > Well, thank you Bill and Jammie. I'm asking this prior to swap dx and An plg's I got. Well, I have a Motif Rack classic, also, with a Dx and Vl plg's. And I would install the Dx plg into the AN200 and the 150An into the Motif. Anyway, is there any danger int swapping cards? > > Lucio > > > > > > from the An200--- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@> wrote: > > > > > > no one knows as no one has tried it > > > > > > but i would think that theres an os eprom that controls it and has the functions of each board to control the front panel features > > > > > > and also the sysex implementation > > > > > > i would get yourself a cheap module that allows 2 cards > > > ----- Original Message ----- > > > From: marcus gaudio > > > To: AN1x-list@yahoogroups.com > > > Sent: Saturday, June 09, 2012 10:36 PM > > > Subject: Re: [AN1x] Re: Hi all: is it possible to insert a PLG150-DX into a AN200? > > > > > > > > > > > > ok > > > so it's possible or not? > > > thanks > > > > > > ________________________________ > > > Da: twobeelandscape <bill@> > > > A: AN1x-list@yahoogroups.com > > > Inviato: Sabato 9 Giugno 2012 17:58 > > > Oggetto: [AN1x] Re: Hi all: is it possible to insert a PLG150-DX into a AN200? > > > > > > > > > Typo error, the PLG150-DX device ID should have been 01100010 62H. Anyway, the important thing is that it is different to the PLG150-AN. > > > > > > Bill > > > > > > --- In AN1x-list@yahoogroups.com, "twobeelandscape" <bill@> wrote: > > > > > > > > There is a further complication in that the PLG150-AN and PLG150-DX have > > > > different device IDs for receiving MIDI system exclusive data (01011100 > > > > 5CH and 01011100 5CH respectively). > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > >
