A lot of the first polyphonic synths had one oscillator and a chorus to thicken the sound. I'm not real familiar with chorus. Could anyone recommend some settings?
Hi Jimmy! Is not easy recomemded you a Chorus setting because depends of many variants you have to consider before. Is a vocal sound, a bass type, a string?
Al this sounds normally work fine with some chorus but.. Is no the same a string pad chorus setting than a bass or lead or any other. Big pads generally need more chorus deep and a also a bigger Wet/dry ratio.
What you can do is starting with a equal 50/50 dry-wet balance and adding more chorus depth level, see how the sound goes and addjust to taste speed and delay settings.
As I said before some sound works better with lees deepth chorus level and need +- wet/dry ratio. Increasing chorus speed can work better is you decreasse chorus level quite and the best setting will be your ears confor area.
