DMANX,
From "10,000 feet," it looks like a DirectX compatibility problem, but not
necessarily a DirectX-CAUSED problem. If you are using an older copy of
DirectX (the latest is 8.0), upgrading may correct the problem. If not,
it's possible that other drivers may need updating, even seemingly
unrelated ones like video and chipset drivers. Windows being the complex,
interactive monstrosity that it is, I've seen strange software connections
before. As an example, I had a Win98 problem with my tape backup, which
was tied to my floppy diskette controller, that was fixed by an update to
my serial port driver.
-BW
Bruce Wahler
Design Consultant
Ashby Solutions"
www.ashbysolutions.com
CloneWheel Support Group moderator
978.386.7389 voice
978.776.0096 fax
bruce@...
At 11:39 p 5/6/2001 +0100, you wrote:
>Hi,
>I have installed win2000 as a test,with cubase5 r4,win2000asio/wdm
>drivers,midi-yoke,midi-ox,plg150an/an150edit,xgdit,SW1000XG,Ensoniq
>wavetable sound card(creative audio pci).However in cubase 5 when i go to
>set up 'Asio Direct Sound Full Duplex Setup' i get a programe error? as
>follows:-
>Dxfdsetup.exe has generated errors and will be closed by windows.You will
>need to restart the program.An error log is being created.
>MME setup and asio multimedia setup seem to work fine,
>Could this be a DirectX problem?
>Please kindly advise
>Regards DMANX.
