The Yamaha AN1x Synthesizer mailing list group photo
Index last updated: 2026-04-28 22:40 UTC
Re: [AN1x-list] Can not rec audio/midi
2001-12-31 by Paul Murphy
I think you need to use HUBIS.
To: <AN1x-list@yahoogroups.com>
Sent: Monday, December 31, 2001 12:05 PM
Subject: [AN1x-list] Can not rec audio/midi
> Hi,
> Im using win XP with my sw1000xg,plg150,an1edit,sblive and cubase
5.1,win2k asio drivers.Im onlt using 2 applications at a time.
> However I can not record midi/audio in cubse5 when using an1xedit.But I
can record from other apps like xgedit..etc.
> When i check my setup in cubase i get a message as follows:-
> ASIO MULTIMEDIA-Not all selected devises in the current configuration were
sucessfully started with selected options.If the card is currently
configured to except a digital signal,and no digital signal is
present,please either reconfigure the card to use internal clock,or apply a
digital signal,orif possible switch this port to except a analog input.
> My current setup is as follows:
> XGedit:
> midi input=none
> midi out A=sw1000synth1
> midi out B=sw1000synth2
> ANX1edit:
> midi input=none
> midi out=sw1000syth1
> midi thru=(unticked)
> Cubase5 setup mme:
> inputs=sw1000 midi in
> outputs=sw1000 synth1 & 2,SWmidi out.
> In cubase5.1 midi options:
> all midi/record filters are unchecked.
> midi thru is checked.
> I would be gratefull if you could knidly advise in this matter.
> Regards Dmanx.
> talk21 your FREE portable and private address on the net at
http://www.talk21.com
> Community email addresses:
>   Post message: AN1x-list@yahoogroups.com
>   Subscribe:    AN1x-list-subscribe@yahoogroups.com
>   Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>   List owner:   AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
>    http://groups.yahoo.com/group/AN1x-list
