AN1xEdit freezes when sending patches to Midi Out
2002-09-01 by pbarbieux
Hello; After sereral hours spent to read this mailing list, I don't find the solution to my problem: I have Windows 98 SE, with Soundblaster Audigy Platinium eX, and I can't use my AN1xEdit (V 1.1): if the Midi Port Setup is on Port I or Port II, the AN1xEdit hangs (not responding) when loading bank or when sending a patch - my AN1x seems to receive a part of SysEx and produces a sound between the current patch and the new patch. I must Ctr-Alt-del to end An1xEdit. If I disconnect the Midi cables, the problem still remains. Sometimes, when assigning a port to Midi In, I receive "UNEXPECTED ERROR!", sometimes it hangs directly. If the Midi Out is assigned to the SoundBlaster Synthesizer (SB Audigy Synth A, for exemple), there is no problem. I have already used the AN1xEdit on the same hardware, but with Windows XP, and I had no problem. I hope somebody can help me. Thank You.
