The Yamaha AN1x Synthesizer mailing list group photo
Index last updated: 2026-04-28 22:40 UTC
Arp Sync(again)
Arp Sync(again)
2002-09-07 by Kambiz Gilani
I search through the entire discussions about syncing
the AN1's Arp to a external midi clock.
Everything make sense until I want to record the
synced material. Does it have to be recorded back on
midi or you just have to go with recording the audio
output of AN1x.
I would rather record the  midi, but this recorded
midi sequence would start the AN1x Arp, which would
create a midi loop. of course I can not record on a
"no output track"!
Kamy
Do You Yahoo!?
Yahoo! Finance - Get real-time stock quotes
http://finance.yahoo.com
Re: Arp Sync(again)
2002-09-09 by jondl_2000
> output of AN1x.
> "no output track"!
> Kamy
It depends...if you have a number of MIDI and Audio tracks
running simultaneously in your MIDI/Audio sequencer (Logic
Audio, Cubase, Sonar, ProTools Free) you might find it beneficial
to simple sync the AN1x Seq/Arp until you're ready for mixdown.
At that point record the AN1x audio output to a stereo track and
then MUTE the track containing the original MIDI data.
Recording the output of the AN1x Arp/Seq into your sequencer
allows you to reassign that data to other MIDI modules and/or
PlugIns - which can be VERY useful! In this case, set the MID Ptn
Tx Ch value (under the VOICE ARP/SEQ menu) to a MIDI
Channel other than the base Trns Ch your AN1x is set too. Once
you've successfully recorded the output from the AN1x Arp/Seq
into your sequencer simply resave the current AN1x Voice with
the Arp/Seq diabled! Now when you recall the AN1x voice in your
sequece it will respond to the note data without double triggering
the Arp/Seq (which I'm sure MANY of us have done inadvertanly
over time.)
HTH.
regards,
Jon
Re: Arp Sync(again)
2002-09-09 by drgilani
> > output of AN1x.
> > "no output track"!
> > Kamy
beneficial
Ptn
Once
your
triggering
> over time.)
> HTH.
> regards,
> Jon
Thanks Jon,
I have another question:
Let say your are syncing the Arp of AN1x to your Logic Song at
140 bpm , but what you need is 280 bmp coming out of AN1x. but
it still have to be in time. how do you do it?
Kamy
Re: Arp Sync(again)
--- In AN1x-list@y..., "drgilani" <drgilani@y...> wrote:
> Thanks Jon,
but
> Kamy
Try halving the timing division of the ARP/SEQ on the AN1x, i.e.,
sixteenth notes in place of eigths notes.
Jon
