Re: [AN1x] An1x AC Adaptor
2004-02-08 by James Acker
I just looked at mine (which is the designated power supply, with the
Yamaha brand name on it) and it is:
12v. DC, 700 mA, (+) positive voltage on inside pin, (-) negative on outside shell.
Mine is for european power, though that is only the input and shouldn't make a
difference as to what needs to be supplied to the unit. So your 1000Ma can
definitely handle the current.
I know with universal power supplies you often can change the shells out, and
polarities, but it occurs to me, somone ought to make an adapter for the one
most used connector type that simply changes polarity...since most common I
think is neg. on the inside pin, but lots more folks lately do the opposite.
Good luck,
Jim
Check out my original music at
http://www.soundclick.com/bands/1/jackermusic.htm
"In theory there is no difference between theory and practice,
but not in practice."
----- Original Message ----- Show quoted textHide quoted text
From: "vikariepoolen" <vikariepoolen@yahoo.se> To: <AN1x-list@yahoogroups.com> Sent: Sunday, February 08, 2004 7:09 AM Subject: [AN1x] An1x AC Adaptor > Hi, > > my An1x came with an ac adaptor that wasn't yamaha original, and now > it is broken (the adaptor). It was a 12 V / 1000 mA adaptor, but I > don't remember the polarities since they're switchable. Anyone got an > original adaptor and can tell me what the data of it is? And, > question number two: will 1000 mA be enough? > > > Andreas
