The Yamaha AN1x Synthesizer mailing list group photo
Index last updated: 2026-04-28 22:40 UTC
re: modwheels
re: modwheels
2005-03-28 by spaceanimals
CC#1 is not a modwheel CC. Rather the modwheel is usually assigned to
send CC#1 data.
CC#1 controls modulation. Only modulation.If your modwheel is assigned
to send CC#1 it will send modulation data. Only modulation data.
The AN200 will respond to modulation data even if everything is zeroed
out because the modulation data is coming from the controller.Hence
the AN200 is not generating any modulation data but it is receiving
modulation data, and therefore modulating.
To have the modwheel control something else, you have to change the
default CC# for the modwheel.The AN200 should have a MIDI chart
explaining what each CC# controls.
Rainbow Jimmy
Re: modwheels
2005-03-28 by Jon
> send CC#1 data.
True, more often then not, because it is a generally accepted standard that CC#1 is
assigned to MW just as CC#7 is often assigned to FV - but it doesn't HAVE to be.
Not entirely accurate as ANY MIDI CC may control modulation.
This also is not entirely correct. If the ModWheel, as in your example - CC#1, is not
assigned a Parameter in the CtrlMatrix it should NOT have any affect. This is how it works
on the AN1x, but we are at a loss to explain why it should differ on the AN200.
No, you would have to change the Parameter assigned to MW in the CtrlMatrix.
As I'm writing this reply I'm running AN Expert Editor (under Classic in OS X) and I see
under for Common [DETAIL] which invokes the 'Detail Parameter' window (also accessible
from the Ctrl Matrix [DETAIL] button) there is a block of parameters for LFO Assign Group
which allows for five different options:
LFO1(All)
LFO1(VCO1,VCO2,VCA) - LFO2(VCF)
LFO1(VCO1,VCO2) - LFO2(VCA,VCF)
LFO1(VCO1) - LFO2(VCO2,VCA,VCF)
LFO2(All)
and then there are parameters for LFO Delay , Key On Reset, and Sync Pmod Sw. From the
AN Expert Editor manual:
"This determines the destination choices for the LFO 1 and LFO 2 modulation.  When one
of the "(All)" settings is selected, all of the available destinations (VCO1, VCO2, VCA, and
VCF) are grouped to the selected LFO, 1 or 2.  The LFO blocks in the main panel control
automatically change when this parameter is set.  The basic parameters of Wave and Speed
(as well as the Detail page) remain intact for both LFOs, no matter what setting is made
here."
It seems to me this setting may be contributing to the problem.
Furthermore info:
"The control change numbers for AN AC 1-4 can be set with the AN Native parameters (on
the panel of the "mother" device).  Each Preset Voice has four pre-assigned control change
numbers using this function (refer to the AN Voice List in the PLG150-AN Owner's
Manual)."
and the manual continues:
" The Control Change numbers for the Mod Wheel, Foot Volume, Foot Control, Footswitch,
Ribbon Controller-X, Ribbon Controller-Z and AN AC 5-8 can be set from the AN1x
System Parameters (refer to the MIDI Data Format section in the PLG150-AN Owner's
Manual)."
I'll hit the manual again with a fresh set of eyes once I've had some sleep ;-)
Jon
Re: [AN1x] re: modwheels
2005-03-29 by Summa
Hi Jimmy,
my Keyboards (the both I tested: microKorg and Casio VZ) aren't sending unusual
"pitch changing, vibrato creating" data to the AN200 and why would changing the
AN200 LFO speed affect this. It's simple CC#1 DATA the mod-wheel is sending,
nothing else and I know how to read a MIDI Implementation Chart...
I'm using MIDI capable Synthesizers for 26 years now, my other 15 synths react on
MOD-Wheel signals as programmed, there's either a global setting (for the older
ones) or a patch setting to change their behavior...
Changing the CC number of the Mod-Wheel isn't possible for most of the Keyboards
I have. Only master/controller Keyboards can do that.
Just bevlieve me that I only want the AN200 to do things that most of my most of
my newer synths are capable too...
...Summa
> send CC#1 data.
> Rainbow Jimmy
> --------------------~--> What would our lives be like without music,
> dance, and theater? Donate or volunteer in the arts today at Network
> for Good! http://us.click.yahoo.com/rKxVKC/SOnJAA/n1hLAA/QnLolB/TM
> Community email addresses:
>   Post message: AN1x-list@yahoogroups.com
>   Subscribe:    AN1x-list-subscribe@yahoogroups.com
>   Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>   List owner:   AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
>    http://groups.yahoo.com/group/AN1x-list
> The AN1x Control Synthesizer FAQ::
>   http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
CZ/VZ 		mailing list	: http://groups.yahoo.com/group/CZsynth
FMHeaven	mailing list	: http://groups.yahoo.com/group/fmheaven/
FS1R 		mailing list	: http://www.ampfea.org/mailman/listinfo/fss-list
Vokator		mailing list	: http://groups.yahoo.com/group/vokator
Wellenform Chat  So and Do 22.00 CET: http://chat.moogulator.com/
