Re: [AN1x] Digest Number 1683
2006-01-09 by Andrea TONI
Hello, be careful cos the bcr2000 uses rotary encoder AFAIK and not normal potmeters ! and there is one more problem with my idea .. once u lock a potmeter in a Joystick case it wont span from 0 to MAX kohm value since the mechanical angle is reduced in the JS mechanism. If the AD converter of the pocket controller can cope with that has to be tested ! It will translate 0-50(100)kohm to 0 128 MidiCC for sure but to what will translate (for example) 15kohm to 30khm range once is inside the JS ? and btw didn't u said on the Wstation list that u had a "perfect for this task" darkstar XP2 ? ;-) Regards --------------------------------------------------Env1-----Env2--Env3----------- Andrea.TONI@... Vco1 \ | | \ Solar-Terrestrial Missions (Sci-Sh) Vco2-->--Vcf-->Vca-->Ducati996 www.rssd.esa.int Vco3 / | | / --------------------------------------------------Lfo1-----Lfo2--Lfo3-----------
> parameters. They have aftertouch, too. > > I dont why it never occured to me, but I guess you could just snitch the > pots out of any MIDI knob box and drop them into a joystick chassis. I have > a Behringer BSR2000 that I use to control my Evolver and MicroModular but I > don't wanna chop that up either. Maybe one of the earlier MIDI knob things > I could get cheap on Ebay or something. > > Thanks for your suggestions, everyone. > > ~snakefooot
