AVR-Chat
PWM problem
PWM problem
2007-10-10 by Thomas Keller
OK, one guy wrote back and said it wasn't possible, but I don't think
that's
correct, because the PWM can also trigger interrupts.  Again:
   I need to drive more than 20 mA to an LED being PWMed by an ATtiny25.
I want to use the PWM module on timer/counter0 to drive an interrupt
routine that sets and clears, as appropriate, a pair of GPIOs driving my
LED
to ~~30-35 mA.  ( I really don't have the physical room in my
environment for
one more transistor, very very tight environment)
   Problem is, the data sheet material on this particular issue has me
confused,
not clear on what I should be doing.  Any help?
tom
Re: [AVR-Chat] PWM problem
2007-10-10 by David VanHorn
Trigger the int, and in the int, set and clear the bits you want.
But know this:  The output current you'll get is quite variable chip
to chip, and batch to batch. Those limits on current in the data sheet
are not guaranteeing any sort of regulation, they are "do not exceed"
numbers, at least in that if exceeded, the port won't be able to hold
the specified voltages for 1 and 0 states.
2007-10-10 by dlc
You wouldn't use PWM to do that, you'd simply use the timer to fire the
ISR at the resolution you want.  For instance, if you want a 1KHz PWM
and you want an 8 bit resolution then you'd need to set your timer to
interrupt every (1ms/256).  Turn the LED on at the beginning of the
cycle and off when you reach the count for the on-time you want.
DLC
> that's
> LED
> environment for
> confused,
> tom
Dennis Clark          TTT Enterprises
www.techtoystoday.com
2007-10-10 by dlc
However, if you parallel the outputs you should be safe.  The Atmel
parts are CMOS outputs, not bipolar so they have a negative temp.
coefficient.  To be the most repeatable I would sink the current and not
source it.
DLC
