AVR-Chat
Re: [AVR-Chat] ATtiny13 - re-using SPI pins?
2007-11-01 by Jim Wagner
It  should also be a circuit that does not care about the
signals during programming.
If it is an SPI peripheral, make sure the Select line is
pulled high with an external resistor because all the other
processor pins are tri-stated with no internal pullup while
ISP is running.
Jim
On Fri, 02 Nov 2007 06:32:39 +1100
 John Samperi <samperi@ampertronics.com.au> wrote:
> At 05:45 AM 2/11/2007, you wrote:
> >What can you
> >"hang off" of the SPI lines to allow the chip to be
> programmed
> Pretty much anything above 1K, but make it as high as
> possible.
> Regards
> John Samperi
> Ampertronics Pty. Ltd.
> 11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
> Tel. (02) 9674-6495       Fax (02) 9674-8745
> Email: john@ampertronics.com.au
> Website  http://www.ampertronics.com.au
> *Electronic Design * Custom Products * Contract Assembly
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
2007-11-01 by Richard Cooke
Hi Folks,
I'm planning on using the ATtiny13 chip because of cost and space
constraints.  I need 2 outputs and 1 A/D input to read the battery
voltage (3V coin cell Lithium) every so often to signal to the end
user that the battery should be changed.
The chip has 6 I/O pins but one needs to be saved for the RESET pin,
and 3 are used for the SPI lines to program the chip.  I've been using
the Dragon to program/debug other designs so I'd like to keep using that.
So now to my question -(sorry for being long winded) - What can you
"hang off" of the SPI lines to allow the chip to be programmed via the
SPI lines but then after the program starts change the pins to an
output and an A/D input?  I'd like to use one of the pins as an output
to drive a resistor divider with the middle connected to one of the
A/D inputs.
Thanks again,
Richard Cooke
2007-11-01 by John Samperi
>What can you
Pretty much anything above 1K, but make it as high as possible.
John Samperi
Re: ATtiny13 - re-using SPI pins?
2007-11-01 by Graham Davies
--- In AVR-Chat@yahoogroups.com, "Richard Cooke" <rcooke@...> wrote:
> ... What can you "hang off" of the
> programmed ...
Not answering your question at all ... if you're not totally committed
to the ATtiny13, consider the pin-compatible ATtiny25, ATtiny45 /
ATtiny85 and program them using just the reset pin using debugWIRE.
Graham.
Re: [AVR-Chat] Re: ATtiny13 - re-using SPI pins?
2007-11-02 by John Samperi
...except the fuses and lock bits of course as DW does not do them.
John Samperi
