Any one doing any projects related to electric utilites?
2007-11-16 by Clark
2007-11-16 by Clark
Hi all My nane is Clark. I'm a beginner as to microcontrollers. I work for a small electric utility in Southern Calif (municipal). I work in the substations & with energy meters. Just wanting to see what others are doing along these lines :-) Thanks
2007-11-22 by Jim Wagner
On Fri, 16 Nov 2007 05:54:37 -0000 "Clark" <cgetty@sgetty.ath.cx> wrote: > Hi all > > My nane is Clark. I'm a beginner as to microcontrollers. > > I work for a small electric utility in Southern Calif > (municipal). I > work in the substations & with energy meters. > > Just wanting to see what others are doing along these > lines :-) > > Thanks > > Have not heard of anyone doing things in this area. There have been a few power meter projects. In this environment, a microprocessor makes the most sense interfacing between sensors, centralizing data, and either logging it directly or sending to some other device such as a PC. "Sensor" might mean current sensor, temperature sense, voltage, real-time clock, etc. I do know that there have been applications where consumer watt-hour meansurements have been done with a micro which then holds a totalized value. The micro is hooked up to something like BlueTooth that can be queried by the meter reader. Best Wishes, Jim Wagner Oregon Research Electronics, Consulting Div. Tangent, OR USA --------------------------------------------------------------- The Think Different Store http://www.thinkdifferentstore.com/ For All Your Mac Gear ---------------------------------------------------------------
2007-11-23 by Philippe Habib
California has mandated that all power meters be switched to remote reading. Right now there are 2 pilot projects and the full rollout should happen within a couple of years. There is also a program in place that installs a thermostat that can be remotely set by the utility so that on hot days they'll turn off your AC for a short time to save power. I think we'll see a whole lot of this stuff in the next few years.
On Nov 22, 2007, at 10:47 AM, Jim Wagner wrote: > On Fri, 16 Nov 2007 05:54:37 -0000 > "Clark" <cgetty@sgetty.ath.cx> wrote: >> Hi all >> >> My nane is Clark. I'm a beginner as to microcontrollers. >> >> I work for a small electric utility in Southern Calif >> (municipal). I >> work in the substations & with energy meters. >> >> Just wanting to see what others are doing along these >> lines :-) >> >> Thanks >> >> > Have not heard of anyone doing things in this area. There > have been a few power meter projects. > > In this environment, a microprocessor makes the most sense > interfacing between sensors, centralizing data, and either > logging it directly or sending to some other device such as > a PC. "Sensor" might mean current sensor, temperature > sense, voltage, real-time clock, etc. > > I do know that there have been applications where consumer > watt-hour meansurements have been done with a micro which > then holds a totalized value. The micro is hooked up to > something like BlueTooth that can be queried by the meter > reader. > > Best Wishes, > Jim Wagner > Oregon Research Electronics, Consulting Div. > Tangent, OR USA > --------------------------------------------------------------- > The Think Different Store > http://www.thinkdifferentstore.com/ > For All Your Mac Gear > --------------------------------------------------------------- > > > > Yahoo! Groups Links > > > >
2007-11-23 by Tom Becker
> ... on hot days they'll turn off your AC for a short time... I'm surprised to hear that California is only now getting around to load shedding. We have had a load shedding program in southwest Florida for >15 years. In my home, we have two ~160MHz receivers which can cycle the units under remote command; they are small gray NEMA boxes located near the AC air handlers and water heaters. On hot days, and the rare cold morning, the ACs are cycled off as the electric cooperative deems necessary but never for more than 15 minutes at a time, and never both of our AC systems simultaneously, and water heaters are also controlled during peaks. I understand the receivers are assigned to one of seven groups which are activated round-robin when required. We receive a ~$60 discount per year. We also have remote-read meters, both for power and potable water. A non-potable recovered supply for irrigation is currently unmetered but use is scheduled. Tom
2007-11-23 by David VanHorn
> There is also a program in > place that installs a thermostat that can be remotely set by the > utility so that on hot days they'll turn off your AC for a short time > to save power. I think we'll see a whole lot of this stuff in the > next few years. Another reason not to live in the People's Republic of California!
2007-11-23 by Roy E. Burrage
I wonder if Malibu, Santa Barbara, and Sacramento will secede. REB David VanHorn wrote: >>There is also a program in >>place that installs a thermostat that can be remotely set by the >>utility so that on hot days they'll turn off your AC for a short time >>to save power. I think we'll see a whole lot of this stuff in the >>next few years. >> >> > >Another reason not to live in the People's Republic of California! > > [Non-text portions of this message have been removed]
On Nov 23, 2007 3:07 PM, Roy E. Burrage <RBurrage@bellsouth.net> wrote: > I wonder if Malibu, Santa Barbara, and Sacramento will secede. Last time I saw it, they were drawing the line at I-80 with a job upward at the end so that Socal could keep Marin.
$60 a year is a lot better than PG&E is offering. They will send someone to install the special thermostat and pay you a one time $25 for signing up.
-----Original Message----- From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf Of Tom Becker Sent: Friday, November 23, 2007 11:45 AM To: AVR-Chat@yahoogroups.com Subject: Re: [AVR-Chat] Any one doing any projects related to electric utilites? > ... on hot days they'll turn off your AC for a short time... I'm surprised to hear that California is only now getting around to load shedding. We have had a load shedding program in southwest Florida for >15 years. In my home, we have two ~160MHz receivers which can cycle the units under remote command; they are small gray NEMA boxes located near the AC air handlers and water heaters. On hot days, and the rare cold morning, the ACs are cycled off as the electric cooperative deems necessary but never for more than 15 minutes at a time, and never both of our AC systems simultaneously, and water heaters are also controlled during peaks. I understand the receivers are assigned to one of seven groups which are activated round-robin when required. We receive a ~$60 discount per year. We also have remote-read meters, both for power and potable water. A non-potable recovered supply for irrigation is currently unmetered but use is scheduled. Tom Yahoo! Groups Links -- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.503 / Virus Database: 269.16.2/1143 - Release Date: 11/21/2007 10:01 AM
2007-11-24 by David Kelly
On Nov 23, 2007, at 1:56 PM, David VanHorn wrote: >> There is also a program in >> place that installs a thermostat that can be remotely set by the >> utility so that on hot days they'll turn off your AC for a short time >> to save power. I think we'll see a whole lot of this stuff in the >> next few years. > > Another reason not to live in the People's Republic of California! Its spelled Kalifornia. Its one thing to give consumers cash incentives for permission to "brown out" their air conditioning or hot water heaters. Its another thing entirely for the government to mandate these controls. -- David Kelly N4HHE, dkelly@HiWAAY.net ======================================================================== Whom computers would destroy, they must first drive mad.
2007-11-24 by Philippe Habib
In this case, the utility pays the consumer if they volunteer to participate.
On Nov 23, 2007, at 7:48 PM, David Kelly wrote: > > On Nov 23, 2007, at 1:56 PM, David VanHorn wrote: > >>> There is also a program in >>> place that installs a thermostat that can be remotely set by the >>> utility so that on hot days they'll turn off your AC for a short >>> time >>> to save power. I think we'll see a whole lot of this stuff in the >>> next few years. >> >> Another reason not to live in the People's Republic of California! > > > Its spelled Kalifornia. > > Its one thing to give consumers cash incentives for permission to > "brown out" their air conditioning or hot water heaters. Its another > thing entirely for the government to mandate these controls. > > -- > David Kelly N4HHE, dkelly@HiWAAY.net > ====================================================================== > == > Whom computers would destroy, they must first drive mad. > > > > > Yahoo! Groups Links > > > >
2007-11-24 by Michael Haisley
Then again, I'd much rather them kill non essential AC/water heaters vs an entire power circuit /neighborhood/etc in a rolling blackout situation. Much less collateral damage when you take out the AC for two neighborhoods, than when you shut off granny's oxygen generator.
On Nov 23, 2007 10:48 PM, David Kelly <dkelly@hiwaay.net> wrote: > > On Nov 23, 2007, at 1:56 PM, David VanHorn wrote: > > >> There is also a program in > >> place that installs a thermostat that can be remotely set by the > >> utility so that on hot days they'll turn off your AC for a short time > >> to save power. I think we'll see a whole lot of this stuff in the > >> next few years. > > > > Another reason not to live in the People's Republic of California! > > > Its spelled Kalifornia. > > Its one thing to give consumers cash incentives for permission to > "brown out" their air conditioning or hot water heaters. Its another > thing entirely for the government to mandate these controls. > > -- > David Kelly N4HHE, dkelly@HiWAAY.net > ======================================================================== > Whom computers would destroy, they must first drive mad. > > > > > > Yahoo! Groups Links > > > >
2007-11-30 by Phillip Vogel
Michael Haisley wrote: > Then again, I'd much rather them kill non essential AC/water heaters > vs an entire power circuit /neighborhood/etc in a rolling blackout > situation. Much less collateral damage when you take out the AC for > two neighborhoods, than when you shut off granny's oxygen generator. > > > Though in that case, the utility company should be informed that there is life-essential equipment in use, and they will not roll that residence into the blackout (or that's how it's supposed to work). And, for the record, in northern NJ we have remote water & gas meter reading, and they're starting to roll out remote electric meter reading. We also have voluntary remote control of AC & water heaters (and you do get paid a small amount annually).
