AVR-Chat
RE: [AVR-Chat] Re: ADC Vref
2007-12-14 by Tim Mitchell
Graham Davies wrote:
> --- In AVR-Chat@yahoogroups.com, "Tim Mitchell" <tim@...> wrote:
>> Why couldn't you use a N-channel
>> fet at the bottom end of the
>> voltage divider, with fairly
>> high resistors for the divider?
> The microcontroller analog inputs are now permanently connected to
> the supplies to be measured via the upper resistors in the divider.
> When your N-channel FET is off, that's their only connection.  If the
> inputs have protection diodes, current will flow, so we don't achieve
> our objective.  If the inputs don't have protection diodes, then they
> will rise to the supply voltage, which is above their maximum rating.
Ah yes. Good point. I remember now that the reason we did it was because
we were using a low vref, but the voltage to be measured was under vcc.
I'll get my coat...
Tim Mitchell
tim@sabretechnology.co.uk http://www.sabretechnology.co.uk
Sabre Technology (Hull) Ltd, 3a Newlands Science Park, Hull HU6 7TQ
Registered in England and Wales no.3131504
t:01482 801003 f:01482 801078
