AVRISP MKII (USB) and Butterfly/carrier not working
2008-01-12 by k5atm
On advice from the list this week I purchased a butterfly carrier to go along with my AVRRISP MKII (USB programmer. I also purchased an ICE Cube. The carrier board kit went together well. I compiled the original butterfly code (ported to winavr) and loaded it fine with the ICE Cube. I also loaded an application I wrote. I then later restored the Butterfly code -- complete with bootloader. So far so good. I tried the above steps again but with the AVRRISP MKII (usb) connected to the ISP connector on the carrier -- but I was not able to get the butterfly to program. The AVRRISP connects OK and when I say program the status light turns from green (connected) to orange (programming) and the USB activity light will flash now and then -- but programming never seems to complete. However, I can use the AVTRISP MKII to read and program fuse bits just fine so at some level it appears to be working. I searched the list archives but found no usefull RISP info. Can anyone verify that the AVRRISP MKII (USB) -- the one Digikey sells for around $30-- should program a Butterfly via the carrier ISP connector? And if so any advice on what might be wrong? Switching topics -- I find that AVRStudio 4 seems to crash alot. I am running a clean machine with XP. The machine has a 2.8GHz processor with 2GB RAM. All OS updates are current. AVR Studio and WinAVR are all current versions. Are crashes just the nature of this beast? Thanks in advance for any advice. -Mike
