AVR-Chat
PWM Help
PWM Help
2008-02-04 by ktal3at
Dear :
i am looking for help to use PWM @mega8535 To contrl Dc Motors
but there is a problem
can any one help me by code and show how can i get the motors fast and
slow ??
thanks
Re: PWM Help
I am controlling the motors by using avr micro control
the way to increase or decrease the motor speed is the PWM
and it is my first time to control motors
so i am looking for help how to use the PWM  and how can i connect the
motors to controller
i know that i must use h-bridge or relay (( i'm using h-bridge))
thanks
Re: [AVR-Chat] PWM Help
2008-02-04 by Roy E. Burrage
An electric motor is basically a Hall Effect device.  By increasing and
decreasing the magnetic flux density you increase and decrease the
angular velocity at which the "armature" rotates inside the fixed
magnetic field of the "field" windings...increase the flux density and
the velocity increases, decrease and it slows.  Varying the field will
do likewise with a fixed armature flux density, within limits, but the
effect is reversed.
Is that what you're looking for?
Google is your friend.
REB
ktal3at wrote:
>Dear :
>slow ??
>thanks
Re: [AVR-Chat] Re: PWM Help
It sounds like you have a need to learn some basic, and very basic at
that, concepts of electricity.  The reason for my smartalecy previous
remark, and the suggestion to use google.  Do a search using the
keywords - DC motor control PWM.  You should get a gazillion or so hits.
REB
>thanks
2008-02-04 by Zack Widup
What kind of motor are you trying to control?  Synchronous AC motors do
not work by PWM.  Stepper motors like the kind used in satellite dish
feed polarotors use PWM. Other steppers require a set of phased pulses
which vary the pulse frequency to control the speed.  Regular DC motors
can be controlled in a variety of ways.
Zack
> thanks
Re: PWM Help
Regular DC motors
How can i control them by using PWM ??
can u help me to generate an ASM Code for it on ATMEGA 8535 ?
2008-02-05 by Dennis Clark
ktal3at wrote:
>  Regular DC motors
   What kind of motors are you using?  What kind of H-bridge.  Your
motor and H-bridge determine what the frequency is that you can use.
For instance, cheapie Mabuchi motors like those used in toys and some
gearboxes can't deal well with higher than 500 Hz.  The L293 H-bridge
can't deal with a PWM frequency higher than about 1-2KHz (I blew the top
off the chip when I accidentally used 19KHz on one!)
We need more details.
   If you don't want to write in assembly, and don't have money for a
compiler then you can use avr-gcc, which runs on Mac, Linux and Windows
and gives a higher level C environment.
DLC
Dennis Clark    TTT Enterprises
Re: PWM Help
2008-02-05 by ktal3at
the main problem for me how to use or generate PWM For increase and
decrease the speed
Re: PWM Help
or can u help me to reach the PID algorithm ? ?
how can i reach it ? ? ?  ??
2008-02-05 by BobGardner@aol.com
It takes one instruction to turn pwm on, one instruction to adjust the duty cycle (example: OCR0=128;) Perhaps a short scan of the datasheet will clear most of this up?
To: AVR-Chat@yahoogroups.com
Sent: Tue, 5 Feb 2008 6:30 am
Subject: [AVR-Chat] Re: PWM Help
decrease the speed
Yahoo! Groups Links
________________________________________________________________________
More new features than ever.  Check out the new AOL Mail ! - http://webmail.aol.com
Re: PWM Help
2008-02-11 by mehdi_saiedmehdizadeh
> thanks
>hi there
you will have lots of problem, i trid it
by
2008-02-11 by Dennis Clark
> the
>> thanks
>>hi there
> by
  Nonsense, there's nothing to it.  The AVR/ATMEGA parts have a single
match register that is used to compare against the PWM timer to
determine duty cycle.  Set your prescale to get the frequency that you
want (usually around 1KHz) and connect the PWM output as you need for
the type of drive that you want: locked-antiphase or sign/magnitude.
Google is your friend, it can find many examples of what I just tersely
described.
DLC
Dennis Clark
TTT Enterprises
AVR32 programmers
2008-02-13 by Manne Tallmarken
Hello folks,
I have coded the AVR's for some time now and want to start looking at the AVR32's. The problem is I don't know how to start.
How do I program it? I want to build my own programmer from scratch, preferrably the simplest one (though it need not to be simple in the sense that
I can build it with four resistors and I gigantic soldering pen). I can make PCB's and stuff like that.
I found this link on google http://www.ixbat.de/index.php?page_id=236
is this one really the simplest one?
can I use my normal isp10 programmer with only four resistors to the AVR32's? if no, why not?
Best regards,
Manne
Re: [AVR-Chat] AVR32 programmers
2008-02-13 by James Wagner
There is an AVR32 section of the AVRFreaks list. You are likely to get
much better answers there.
Jim Wagner
On Feb 13, 2008, at 2:24 PM, Manne Tallmarken wrote:
> Hello folks,
> sense that
> Best regards,
> Manne
