AVR-Chat
DC swiching power supply
2008-03-20 by M F
hi friends
have u ever worked at any switching circuits? i want
to design a DC power supply.may i use 555 Ic's??
is there any sites to help me.your ideas could help
me.
let me know if u have designed a switching power
supply
thank u
have a nice spring holidays
Shervin
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
Re: [AVR-Chat] DC swiching power supply
2008-03-21 by Zack Widup
I've designed quite a few. What are your power requirements?  What
voltages in and out?  What maximum current out?
There are far better ways to do it than with a 555.  But that will work if
you only need small currents.
Zack
On Wed, 19 Mar 2008, M F wrote:
> hi friends
> me.
> supply
> thank u
> Shervin
2008-03-21 by LEON HELLER
M F <ektenad@yahoo.com> wrote:  hi friends
me.
supply
I have, I used an AT90S2313.
  Leon
2008-03-21 by Dennis Clark
Maybe I've lost the spirit of discovery, but I see no reason to design a
new power supply when there are dedicated switching controllers out
there for a song (low cost).
  Is there a reason you want to do this the hard way?
DLC
> hi friends
> me.
> supply
> thank u
> Shervin
Dennis Clark
TTT Enterprises
2008-03-21 by James Wagner
Shervin -
Yes, you probably could, but the 555 only represents a small part of
what would go into a switch-mode power supply. Further, the 555 is
really designed to vary its  duty cycle or pulse width based on
external resistors and not voltages. This makes it harder to use for
this kind of application than one would really like. IF you REALLY
want to experiment and learn what the challenges are for making a
SMPS, then charge on. However, since you are posting on an AVR list, I
would assume that your goal is to power an AVR or peripheral circuits.
If that is the case, then you will be spending a LOT of time on
something that really is secondary to your end goal.
I can understand, if you are in a part of the world where electronic
components are hard to get and you may only have access to 555s and
741 op amps and such. There are some switcher "cores" that have been
around for a LONG time and are very low cost and widely available.
Unfortunately, I can't find any references to what I remember, but I
do know that they are out there. Unfortunately, if your problem is
finding modern components, you will also have problems getting
Schottky diodes and power inductors you really need for such a supply.
Jim Wagner
> design a
> DLC
> > hi friends
> > me.
> > supply
> > thank u
> > Shervin
> > Yahoo! Groups Links
> Dennis Clark
> TTT Enterprises
2008-03-21 by Roy E. Burrage
Try an MC34063A, UA3843A, or an LM3425A will all do what you want and do
it very economically.  The first two come in an 8 pin DIP and the last
one is a 16 pin DIP.  All are easy to use, which to use depends upon the
application.
REB
James Wagner wrote:
> Shervin -
> Jim Wagner
>> design a
>> DLC
>>> hi friends
>>> me.
>>> supply
>>> thank u
>>> Shervin
>>> Yahoo! Groups Links
>> Dennis Clark
>> TTT Enterprises
The MC34063A was what I was remembering. Thanks, Roy.
Jim
> and do
> the
> application.
> REB
> James Wagner wrote:
> > Shervin -
> list, I
> circuits.
> supply.
> > Jim Wagner
> >> design a
> >> DLC
> >>> hi friends
> >>> me.
> >>> supply
> >>> thank u
> >>> Shervin
> >>> Yahoo! Groups Links
> >> Dennis Clark
> >> TTT Enterprises
> > Yahoo! Groups Links
