AVR-Chat
Protecting the ADC
Protecting the ADC
2008-11-18 by xolang1
Hi
I have an ATmega128 utilizing the ADC to read voltage from a
thin film vibration sensor that generates voltages from 0 - 70V.
Im currently using a simple resitor voltage divider to scale down
this 0-70V to 0-5V. To protect the ADC pin, i have a 5V Zener
across the ADC input.
Question: is this set-up sufficiently protected?
any suggestions?
Thanks in advance for the help.
chris
Re: [AVR-Chat] Protecting the ADC
2008-11-18 by Jim Wagner
On Nov 17, 2008, at 9:19 PM, xolang1 wrote:
> Hi
> any suggestions?
> chris
A zener is not a particularly good choice. It is too "soft" at its
breakdown. Further, if it is really rated at 5.0V, it will have some
tolerance (probably 10% for an ordinary zener) and this could make the
breakdown as low as 4.5V. I would use a small reverse-biased Schottky
diode from the ADC input to Vcc.  Let the source resistance of the
divider limit the current. This will keep the input from exceeding the
max of Vcc+0.3V that is a common spec.
Jim Wagner
Oregon Research Electronics
2008-11-18 by Dao Viet Dung
All of the ATmega series themself have protected diode inside. So you should find the other way to protect it.
--- On Tue, 11/18/08, Jim Wagner <wagnerj@proaxis.com> wrote:
Subject: Re: [AVR-Chat] Protecting the ADC
To: AVR-Chat@yahoogroups.com
Date: Tuesday, November 18, 2008, 12:30 PM
> Hi
> any suggestions?
> chris
Jim Wagner
Appreciate the help guys. that was informative.
the datasheet indeed says the ADC's are internally diode protected.
so then it seems the current circuit would suffice.
thanks!
Date: Tuesday, November 18, 2008, 4:17 PM
To: AVR-Chat@yahoogroup s.com
> Hi
> any suggestions?
> chris
Jim Wagner
2008-11-18 by Kathy Quinlan
NO, the internal diodes are not designed for this level of protection,
depending on your external resistor values, you could exceed the maximum
sink current of the device.
An external reverse-biased Schottky will provide the extra protection
needed.
I believe in belts and braces, I would rather have a device in the field
that does not lock up than a device that I saved a cent or two on in
manufacturing.
Kat.
> thanks!
> <mailto:vietdung79%40yahoo.com>> wrote:
> From: Dao Viet Dung <vietdung79@yahoo.com <mailto:vietdung79%40yahoo.com>>
> To: AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com>
> From: Jim Wagner <wagnerj@proaxis. com>
> > Hi
> > any suggestions?
> > chris
> Jim Wagner
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.175 / Virus Database: 270.9.4/1795 - Release Date: 17/11/2008 5:24 PM
the source resistance should be around 50-75k
which should be sufficient for current limiting.
for over voltage protection, reverse Ge diodes (0.3V) will be
placed from adc to vcc and gnd to adc.
any thing missed or inappropriate?
--- On Tue, 11/18/08, Kathy Quinlan <kaqdialup@iinet.net.au> wrote:
> From: Kathy Quinlan <kaqdialup@iinet.net.au>
> Date: Tuesday, November 18, 2008, 8:11 PM
> protection,
> exceed the maximum
> protection
> needed.
> in the field
> two on in
> manufacturing.
> Regards,
> Kat.
> diode protected.
> > thanks!
> inside. So you
> > > Hi
> voltage from a
> have a 5V Zener
> > > any suggestions?
> > > chris
> "soft" at its
> will have some
> this could make the
> resistance of the
> from exceeding the
> > Jim Wagner
By doing it that way you can also protect from reverse spikes, which is
a great idea.
> > protection,
> > exceed the maximum
> > protection
> > needed.
> > in the field
> > two on in
> > manufacturing.
> > Regards,
> > Kat.
> > diode protected.
> > > thanks!
> > inside. So you
> > > > Hi
> > voltage from a
> > have a 5V Zener
> > > > any suggestions?
> > > > chris
> > "soft" at its
> > will have some
> > this could make the
> > resistance of the
> > from exceeding the
> > > Jim Wagner
> > > Checked by AVG - http://www.avg.com <http://www.avg.com>
2008-11-18 by Zack Widup
A couple questions: Are the resistors in the divider and the zener
surface-mount devices or leaded devices? And what current is the vibration
sensor capable of producing at 70 volts?
Chip components have a tendency to develop minute cracks when under a lot
of vibration. I've had that happen before where the cracked part was
easily seen but I had it happen recently where I couldn't tell which part
was bad and just about went around the bend trying to find it. Leaded
parts are less likely to crack under vibration.
Also, from my experience with zeners going bad, 90% of the time they
become short-circuits when they go bad. If there's enough current behind
the source to blow out the shorted zener, you're in trouble.
Other than those two areas, I'd say your idea itself would provide
adequate protection.
Zack
On Mon, 17 Nov 2008, xolang1 wrote:
> Hi
> any suggestions?
> chris
2008-11-18 by David VanHorn
On Tue, Nov 18, 2008 at 7:11 AM, Kathy Quinlan <kaqdialup@iinet.net.au> wrote:
Definitely correct.  Although the internal protection diodes exist,
you are never supposed to use them.
A series resistor to limit current, schottky diodes to VCC and ground,
and another resistor into the ADC input pin is about the minimum I'd
use.
For real protection, a buffer op-amp would be better.
A lot depends on how much current this device can source, but I
suspect it's pretty low.
I did a battery management system recently that had to work with 6V -
48V input of any polarity, AND be "taser-proof" on the input leads.
That was fun.
2008-11-18 by David Kelly
> > protection, depending on your external resistor values, you could
> > exceed the maximum sink current of the device.
People these days tend to forget The Bad Old Days when most every IC was
super sensitive to static discharge during handling. They are still
sensitive but not anything nearly as bad as they once were when one
could almost zap gates with ESP (Extra-Sensory Perception, just by
thinking).
There is/was an Atmel appnote on building an electric power meter where
240 VAC was connected directly to an input pin through a 1 or 10 megohm
resistor, stating the protection diode was safe up to 1 mA. And then the
appnote went to lengths disavowing the safety ...
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
> thinking).
Yes.. Many of the little details are getting lost. The interesting
failure mode of most three terminal regulators, how to properly select
a crystal and it's caps for a micro, proper PCB layout..
YIKES!   I suppose if the circuit were entirely within a
non-conductive enclosure, and the user had NO way to touch it at
all...
Engineering IS the art of compromise, but sometimes you do wonder what
the hell they were thinking.
