LCD Display Problems
2008-12-02 by Jeremy
I'm tinkering with a 16x2 HD44780 LCD display attached to my dragon
rider. The uC is a ATmega32 feeding the LCD through PortA and using
JTag as the debugger/programmer. I am using Peter Fleury's lcd
libraries (http://jump.to/fleury). The only thing I've changed in the
header is that Im connecting to a 2 line LCD on PortA and running at
8Mhz.
The problem I am getting is pertaining to the code I have posted
below. It seems I am getting artifacts on my screen and I'm not quite
sure why? I am running a couple loops in order to marquis topstr and
lowstr across the lcd display on both lines. The top one comes from
the right and the lower from the right. They work fine except for
erroneous text I keep seeing on the display. (I drew an image as an
example. The ¶- artifact starts in the middle and scrolls opposite of
what that line is suppose to do. I thought maybe it's displaying extra
information in memory as when I have put userChars into memory to
display it, the ¶ changes to the character from userChars but reverts
if I remove the code which introduces userChars (as you can see I have
it commented out now). Erasing the Flash and EEPROM memory doesnt seem
to change anything. After a reprogramming, it just reverts back to the
same problem.
If any of you have used Peter Fleury's lcd code or might know what is
going on through this rough but I hope extensive description, I would
appreciate the help. Thanks
What it should look like (the two stars move towards eachother to the
opposite side)->
What it looks like (the artifact moves with the upper star from the
middle till it meets the bottom star and disappears)->
-Code-
#include <avr/io.h>
#include "lcd.h"
#include <util/delay.h> // _delay_ms(#) Header
#include <avr/pgmspace.h> // To access eeprom
//static const PROGMEM unsigned char userChars[] =
// 0x0,0xA,0x1F,0x1F,0xE,0x4,0x0,0x0 // Test character
void delay_ms(int cnt)
while(cnt-->0) _delay_ms(1);
int main(void)
const char topstr[16]="*---... ";
const char lowstr[16]="*---... ";
int i = 15;
int j = 0;
int k = 0;
lcd_init(LCD_DISP_ON); //Initialize LCD with the cursor off
lcd_clrscr(); //Clear the LCD screen
lcd_home();
for (i = 15; i >= 0; i--)
lcd_gotoxy(i,0);
lcd_puts(topstr);
for ( j = 0; j < k+1; j++)
lcd_gotoxy(k-j,1);
lcd_putc(lowstr[j]);
k++;
delay_ms(500);
lcd_clrscr();
// lcd_command(_BV(LCD_CGRAM));
// for(int i=0; i<8; i++)
// lcd_data(pgm_read_byte_near(&userChars[i]));
for (;;)
// lcd_gotoxy(0,1);
// lcd_putc(0);
// Do nothing forever (Message already
displayed on LCD)
