AVR-Chat
ATmega8l
ATmega8l
2008-12-16 by bluesky_15_8
hi all
well this is my first time to programing micro controller so i will use
proteus program to be sure first that the program will be in  a right
way to make simulation so i want your help if u don't mind plz  . i use
proteus before but how can i use it with micro . i don't have till now
a good idea . i want to make control on the speed of fan this fan will
decrease the temperature in a small box but i have a question in my
circuit i will use temperature sensor i think that its output will be
sure voltage so i will put voltage source to the input of the micro or
do we have the ability to use the sensor in the proteus
thank u for reading my e_mail . i wait for ur replay  .BYE
Re: [AVR-Chat] ATmega8l
2008-12-16 by Jim Wagner
On Dec 15, 2008, at 9:54 PM, bluesky_15_8 wrote:
> hi all
> use
Its not clear what you are asking. If your temperature sensor has a
voltage output, then you probably want to use the analog-digital
converter (ADC) of the micro. Then, you wold probably want to use PWM
to control the fan motor, depending on the kind of motor it is.
Jim Wagner
Oregon Research Electronics
2008-12-16 by Richard Reeves
I could describe how to do it, but it would be far better to point
you in the direction of the help file first, which is found in ISIS's
Help->Proteus VSM Help.  There is a whole section on working with
microprocessors.  If you've used Proteus enough to simulate non-
programmable circuits, then the AVR simulation isn't a big step.
I would, however offer the following advice:
The more recent models (from the 'AVR2' library) simulate the reset
pin as open=low, so for the Mega series, tie it high or your
simulation won't run.
This is based on using AVR Studio and WinAVR - Save your Proteus work
in the same directory as the .aps of you project and load the .elf
file into the AVR.  That way you get source-level debugging.
If you have problems using it (and you have a legal copy of Proteus),
I recommend going to Labcenter's user forums here:
http://support.labcenter.co.uk/forums/index.php
Richard
