Re: [AVR-Chat] ATmega8l
2008-12-17 by blue sky
hi jim yes of course the temperature sensor output is analog so i will use ADC and i will not use motor no i use fan with 5vDC yah it is small the main thing i ask that what is the important part that i must take care to do when i use proteus with micro . i will write my program using c language so it will be easy or using what .i have read in c language before so i think it will be not dif --- On Mon, 12/15/08, Jim Wagner <wagnerj@proaxis.com> wrote:
Subject: Re: [AVR-Chat] ATmega8l
To: AVR-Chat@yahoogroups.com
Date: Monday, December 15, 2008, 10:19 PM
On Dec 15, 2008, at 9:54 PM, bluesky_15_8 wrote:
> hi all
> well this is my first time to programing micro controller so i will
> use
> proteus program to be sure first that the program will be in a right
> way to make simulation so i want your help if u don't mind plz . i use
> proteus before but how can i use it with micro . i don't have till now
> a good idea . i want to make control on the speed of fan this fan will
> decrease the temperature in a small box but i have a question in my
> circuit i will use temperature sensor i think that its output will be
> sure voltage so i will put voltage source to the input of the micro or
> do we have the ability to use the sensor in the proteus
> thank u for reading my e_mail . i wait for ur replay .BYE
Its not clear what you are asking. If your temperature sensor has a
voltage output, then you probably want to use the analog-digital
converter (ADC) of the micro. Then, you wold probably want to use PWM
to control the fan motor, depending on the kind of motor it is.
Jim Wagner
Oregon Research Electronics
