AVR-Chat
AVRISP programming
AVRISP programming
2009-01-25 by xolang1
Hi Guys,
I have a board with atmega128L and have sucessfully programmed the chip using an AVRISP. However after adding some components on board, I get "AVRISP Error entering programming mode" in codevision and a similar message in AVRstudio.
- I know that the AVRISP is working as I have been able to program another circuit board w/ a mega64.
- I tried using STK500 programmer with the mega128 board, but I get the same error.
- the programming pins are directly connected to the AVRISP port via 600ohm ferrite beads.
- I tried to insert a 12k pull up resistor on the reset pin, but same reults
- The components I have added before the board wont program are several zener diodes across some GPIO's and 2 vibration sensors.
- The last code I have programmed on the chip seemed to work. so i could not be certain if it is the chip that is damaged.
- changing the chip would be the last option as i have already changed
before and the PCB is starting to be damged. I would really appreaciate
if u guys could enlighten me on how to proceed.
thanks!
Chris
Re: [AVR-Chat] AVRISP programming
2009-01-25 by Christopher Baker
Thhis may or may not help, but I had a similar problem before. I had
an LED on my miso and mosi pins. When trying to program the chip in-
system, the LEDs would flash and I don't think the voltage threshod
was high enough to reprogram the chip, resulting in an obscure error.
My solution was to unplug the LEDs while programming. This was a
prototyping board tho. Don't rewire till you get somemore input from
other person
On Jan 25, 2009, at 12:29 AM, xolang1 <xolang1@yahoo.com> wrote:
> Hi Guys,
> the same error.
> same reults
> appreaciate
> thanks!
> Chris
2009-01-25 by Roy E. Burrage
If you plan to use the ISP and external circuits on the programming
pins, Chris, you should always put a resistor in series with the
external circuits so they don't load down the ISP signals ... not to
mention possible unintentional damage to your external system in some
manner.  An alternative would be to use a multiplexer similar to a
CD4066 or a CD4052.  Jumper select the source when programming and
you're good to go.
REB
xolang1 wrote:
> Hi Guys,
> thanks!
> Chris
thanks guys, but...
As I am using mega128, the the prog pins are shared with UART on PE0 and PE1 whcih are also conencted to a max202 chip. I have no prolem programing the chip even with this set up in this board before. So i assume it should not be aproblem in this case.
another other suggestion/input?
i will try to disconnect the Vcc of the max202 and see
thanks
-chris
--- On Sun, 1/25/09, Roy E. Burrage <RBurrage@bellsouth.net> wrote:
Subject: Re: [AVR-Chat] AVRISP programming
To: AVR-Chat@yahoogroups.com
Date: Sunday, January 25, 2009, 4:58 PM
you're good to go.
REB
xolang1 wrote:
> Hi Guys,
> thanks!
> Chris
2009-01-25 by John Samperi
DONT!!!! You are only making things worse as the whole
chip will try to power up from the TX pin and the programmer.
You have most likely BLOWN up all of the programmers used
as they will be fighting with the output of the MAX 202.
If nothing has blown up then:
Either use a jumper to isolate the RX pin from the MAX202 during
program or use a 1K resistor (minimum) between the pin RX of the
M128  and the output of the MAX202.
Throw away ANYTHING that is between the programmer and the programming
pins of the chip.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
