Re: [AVR-Chat] Sensor
2009-05-13 by Jeffrey Engel
If a little noise can be tolerated in the sensor input, you can add air to the tube. As the bubbles leave the end of the tube, they'll bounce the pressure a little. Some of the advantages are that you can put the gauge at the top of the tank, it's cheap and easy to repair. If you're measuring water (or similar to water density), use a gauge calibrated in in/h2o and read the depth out directly. Jeff Engel Happiness is - positive intake manifold pressure. --- On Wed, 5/13/09, David Kelly <dkelly@hiwaay.net> wrote:
Subject: Re: [AVR-Chat] Sensor
To: AVR-Chat@yahoogroups.com
Date: Wednesday, May 13, 2009, 12:51 PM
On Wed, May 13, 2009 at 09:47:39AM -0700, Bruce Parham wrote:
> Sorry, my earlier response was incomplete, just the germ of an idea.
> Since the inverted standpipe is initially filled with air, when the
> liquid level rises, the gas will be compressed allowing liquid to
> enter the tube which will reduce the pressure head. The actual
> pressure measured will depend on the total volume of the tube and the
> amount displace by liquid but will always be less than the pressure at
> the bottom of the tube.
> -- The gas compression correction is left as an exercise for the
> student. --
All to avoid purchase of a sensor which won't be damaged by the liquid?
The compressed air in the inverted standpipe will eventually dissolve
into the liquid. This proposed solution will not work in a static
situation, must be cyclical allowing the air in the standpipe be
refreshed periodically.
David Kelly N4HHE, dkelly@HiWAAY. net
Whom computers would destroy, they must first drive mad.
