AVR-Chat
digital thermometer
digital thermometer
2009-05-18 by alex levenie
hi everybody,i hope you all be fine
my circuit is a digital thermometer using two lm35(sensor), atmega8(master), two atmega 32(slaves)
the master must read two sensors output voltage and send each one to different slave ,
the slaves must show the tempreture according to corresponding formula ,
but the circuit dosn't work,it just show the primary data on lcd ("hello...")
but after the turning on the circuit ,I must disconnect and connect the power supply in a very short time to make the circuit show the tempreture,also sometimes one of slaves show (after that work) sometimes two , sometimes none of them
please help me
here is the master program:
Chip type           : ATmega8
Program type        : Application
Clock frequency     : 1.000000 MHz
Memory model        : Small
External SRAM size  : 0
Data Stack size     : 256
#include <mega8.h>
#include <delay.h>
// SPI functions
#include <spi.h>
#define   Slave_select_1  PORTD.7
#define   Slave_select_2  PORTB.0
#define   ADC_VREF_TYPE  0xE0
unsigned char read_adc(unsigned char);
void main(void)
PORTB=0x00;
DDRB=0x2D;
PORTD=0x00;
DDRD=0x80;
// ADC initialization
// ADC Clock frequency: 125.000 kHz
// ADC Voltage Reference: Int., cap. on AREF
// ADC High Speed Mode: Off
ADMUX=ADC_VREF_TYPE;
ADCSRA=0x83;
SFIOR&=0xEF;
// SPI initialization
// SPI Type: Master
// SPI Clock Rate: 250.000 kHz
// SPI Clock Phase: Cycle Start
// SPI Clock Polarity: High
// SPI Data Order: LSB First
SPCR=0x7C;
SPSR=0x00;
Slave_select_1=1;
Slave_select_2=1;
while (1)
      Slave_select_1=0;
      spi(read_adc(5));
      Slave_select_1=1;
      Slave_select_2=0;
      spi(read_adc(4));
      Slave_select_2=1;
      delay_ms(500);
and this is the slave program:
Chip type           : ATmega32
#include <mega32.h>
// SPI functions
#include <spi.h>
#include <stdio.h>
#include <stdlib.h>
#include <delay.h>
// Alphanumeric LCD Module functions
#asm
   .equ __lcd_port=0x12
#endasm
#include <lcd.h>
char buffer_lcd[40],lcd[40];
void main(void)
PORTB=0x00;
DDRB=0x40;
PORTD=0x00;
DDRD=0x00;
// SPI Type: Slave
SPCR=0xEC;
SPSR=0x00;
// Clear the SPI interrupt flag
#asm
    in   r30,spsr
    in   r30,spdr
#endasm
lcd_init(20);
lcd_clear();
lcd_putsf("hello");
delay_ms(1000);
lcd_clear();
lcd_putsf("micolab project");
delay_ms(1000);
lcd_clear();
lcd_putsf("first semester");
delay_ms(1000);
lcd_gotoxy(0,1);
lcd_putsf("2009");
delay_ms(2000);
// Global enable interrupts
#asm("sei")
while (1);
// SPI interrupt service routine
interrupt [SPI_STC] void spi_isr(void)
   unsigned char data;
   float temp ,index;
   data=SPDR;
   index=data*2.56/256;
   temp=index/0.01;
   lcd_clear();
   ftoa(temp,2,buffer_lcd);
   sprintf(lcd,"temp %2s \xdfc ",buffer_lcd);
   lcd_puts(lcd);
that's all , please help me
Re: [AVR-Chat] digital thermometer
2009-05-18 by John Samperi
What does the hardware look like? Do you have a good reset circuit
or use the BOD?
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
Re: digital thermometer
2009-05-19 by Brian
Im not strong in SPI but is there sufficent delay in the spi.h to allow data transfer before you set the slave select high? Try adding a 30 ms delay after the adc mesurement and before setting the slave select to high. this should give enough time for slave 1 to recieve the data before slave 2 sets to recieve data. I cant see nothing else wrong but I am only a beginner.
Brian
> please help me
> Chip type           : ATmega8
> #include <mega8.h>
> #include <delay.h>
> // SPI functions
> #include <spi.h>
> void main(void)
> PORTB=0x00;
> DDRB=0x2D;
> PORTD=0x00;
> DDRD=0x80;
> ADCSRA=0x83;
> SFIOR&=0xEF;
> // SPI Type: Master
> SPCR=0x7C;
> SPSR=0x00;
> Slave_select_1=1;
> Slave_select_2=1;
> while (1)
>       Slave_select_1=0;
>       spi(read_adc(5));
>       Slave_select_1=1;
>       Slave_select_2=0;
>       spi(read_adc(4));
>       Slave_select_2=1;
>       delay_ms(500);
> #include <mega32.h>
> // SPI functions
> #include <spi.h>
> #include <stdio.h>
> #include <stdlib.h>
> #include <delay.h>
> #asm
> #endasm
> #include <lcd.h>
> void main(void)
> PORTB=0x00;
> DDRB=0x40;
> PORTD=0x00;
> DDRD=0x00;
> // SPI Type: Slave
> SPCR=0xEC;
> SPSR=0x00;
> #asm
>     in   r30,spsr
>     in   r30,spdr
> #endasm
> lcd_init(20);
> lcd_clear();
> lcd_putsf("hello");
> delay_ms(1000);
> lcd_clear();
> delay_ms(1000);
> lcd_clear();
> delay_ms(1000);
> lcd_gotoxy(0,1);
> lcd_putsf("2009");
> delay_ms(2000);
> #asm("sei")
> while (1);
>    unsigned char data;
>    float temp ,index;
>    data=SPDR;
>    temp=index/0.01;
>    lcd_clear();
>    lcd_puts(lcd);
