avrdude, TINY2313 and writing EEPROM problem
2009-06-27 by dlc
I have avrdude 5.5 and I'm pleased as can be with it, until now. I am using the avr libc EEPROM routines and setting the EEPROM memory up properly to start with data in the EEPROM. I've confirmed that the eep file is fine. When I try to program my TINY2313 nothing after byte 3 gets properly programmed in the EEPROM. Sometimes it says everything is fine on the read back, but it isn't and sometimes avrdude tells me that the third byte doesn't verify. I've Googled for this but found no definitive answer, I have not visited the avrdude site yet to search the bug data base. Has anyone seen this before and solved it? Is there a later version of avrdude that fixes the problem? Am I simply doing something wrong? thanks, DLC -- ------------------------------------------------- Dennis Clark TTT Enterprises www.techtoystoday.com -------------------------------------------------
