AVR-Chat
Reset interrupt handler
2009-08-13 by Adeilton Oliveira
Hello Guys,
I'm working with ATMEGA328P (Arduino Board) in C, in AVR Studio and AVR
Dragon. When I download and run, every time I press the reset button the
board freezes.
Could anyone suggest a reset interrupt handler I can use in my project?
I am more familiar with Assembly and in this case it would be
straightforward, but in C I don't know how the compiler handles this.
Thank you in advance.
Re: [AVR-Chat] Reset interrupt handler
2009-08-14 by Dennis Clark
> Hello Guys,
> board freezes.
  Reset takes you to "location 0", the same as a power up.  If you are
using an Arduino that restart location is the bootloader.  Some of the
Arduino bootloaders that I've seen hang out there for several seconds
before jumping to user code.  How long do you wait before you decide
that you've "frozen"?
DLC
Dennis Clark
TTT Enterprises
2009-08-15 by Adeilton Oliveira
Dennis
I have a blinking LED using timer interrupt. This is what I use to check
if the board is working or not.
When I program the board with debugWIRE and run the code, the LED stops
blinking in on or off state just after I press the reset button.
After more tests programming and running the code, I left the debug
session after pressing "disable debugWIRE" in AVR Studio. It was a
surprise for me the board restarted running my code after I pressed
reset button.
My conclusion is the board stays in debugWIRE mode unless I press the
disable debugWIRE in AVR Studio. If I do not press the button and exit
the software, debugWIRE is not disabled and something wrong happens when
I press reset button.
Solution: always press "disable debugWIRE".
Adeilton Oliveira
GMB
Dennis Clark wrote:
> > Hello Guys,
> > board freezes.
> DLC
> Dennis Clark
> TTT Enterprises
2009-08-15 by John Samperi
Absolutely correct otherwise you have no reset (pin used by DW).
You can also use the BOD to help with resets.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
