RE: [AVR-Chat] prevent attiny2313 flash corruption
2009-11-04 by Tim Mitchell
----Original Message----
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf Of David VanHorn Sent: 04 November 2009 13:59 To: AVR-Chat@yahoogroups.com Subject: Re: [AVR-Chat] prevent attiny2313 flash corruption > You need to make sure that the write will complete before > power goes > out of spec. > You also need to make sure that the address you're > writing to is > correct, and that the data is correct. > > Generally, when not actively using the EE, I leave the > EEAR pointing > at 0x00, so that a wild write for whatever reason, should > overwrite > this address, which I dont use. > > When I set up a program to specifically investigate this > in the 8515, > I never caught a single instance of EE corruption, when > the code > followed the rules above. Sorry, are we talking about Flash (ie program memory) or Eeprom corruption here? I have experienced Eeprom corruption caused by dodgy power. Never seen or heard of flash corruption. -- Tim Mitchell
