AVR-Chat
90can128 can controller
2009-12-16 by blue_eagle74
I have read the datasheets and researched the net. I used the CV wizard to set the can up. How do I send data?
Is there an example of sending data of switch positions, 8 bit, from one micro to another and displaying it using CV?
Brian
RE: [AVR-Chat] 90can128 can controller
2009-12-16 by Dave McLaughlin
Hi Brian,
If your C programming is good, you could try porting the Atmel CAN bus
library to CV.
I did this for a project last year and it works pretty well once you figure
out how it works. Needs a bit of work to get it going under CV but it can be
done.
Good luck, CAN is superb once you get it work. Very reliable and robust.
Dave.
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of blue_eagle74
Sent: 16 December 2009 10:17
To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] 90can128 can controller
Brian
Re: 90can128 can controller
Thanks, I have the files just need to figure out how to use them. Any hints?
Brian
--- In AVR-Chat@yahoogroups.com, "Dave McLaughlin" <dave_mclaughlin@...> wrote:
> Hi Brian,
> library to CV.
> done.
> Dave.
2009-12-31 by blue_eagle74
I have searched and searched but cant find what I need. Can anyone provide a simple C code in CV using the CANbus. A simple one for transmit and/or request info from the other AVR. I just want to talk to another AVR and have it respond and turn on an LED so I can see that it works.
I have found code but dont understand it. Does anyone have a tutorial?
Brian
I am using CodeVision to compile and load the chips.
I have seen many sites that describe the CAN. I have used the CV wizard to set up the CAN using only MOB1 but don't know how to start sending or recieving data or where to get the data.
Brian
> The CAN controller in the device needs a fair bit of work to fully
> understand it and also a good understanding of CAN to be able to use it
> fully.
> There is quite a bit to setup the device to make it work and it took me
> about 1 week with the code from the Atmel website, porting it to the
> Codevision compiler before it would work. It is ready to go with the WinAVR
> I believe so if you have that compiler, you should be able to figure it out?
> I was already familiar with the Microchip MCP2515 before but moving to the
> AVR CAN took me a whilst to figure out and I am still working on it.
> CAN does not work as a request and get data, except for certain situation
> where you do a request. Normally, CAN devices just send data on event or at
> preset times. For the likes of digital inputs, I would only send a message
> on the bus if there was a change. For analog I would send at a preset rate.
> The beauty of CAN is that you don't have to worry about having a master with
> multiple slaves as you would with the likes of RS485. You simple ensure that
> each device on the bus sends a unique ID for each message. CAN messages are
> based on priority so a higher priority message goes first if 2 devices try
> to send data at the same time. This reduces your workload in the processor
> to very little and you simple set the buffer to transmit and let the CAN
> controller do the work of sending the message and detecting errors.
> Remember that CAN is source message based. That means there is no
> destination address. The remote devices know which messages they are
> interested in and are usually setup with the message filters to only receive
> those messages. This bit takes a fair bit of work to understand but once you
> do, it will be easy to create remote devices listening only for required
> messages.
> Which compiler are you using?
> Dave.
RE: [AVR-Chat] Re: 90can128 can controller
2009-12-31 by Dave McLaughlin
fully.
messages.
Dave.
Of blue_eagle74
Sent: 31 December 2009 10:37
Subject: [AVR-Chat] Re: 90can128 can controller
Brian
I will fire up my compiler later and see if I can give you some pointers
from the Atmel code.
Dave.
Of blue_eagle74
Sent: 31 December 2009 11:30
Brian
That would be great. Thank you.
Brian
> Dave.
2010-01-03 by blue_eagle74
I just got my 50/100 card edge connectors and have made my eaglecad drawing so I can etch my boards for my backplane. I will have two backplanes with 5 connectors each with ribbon cable connecting them. My order was shorted the connectors for the ribbon cable but I called them and the sockets are on the way. The hard part is the programming so the chips can talk to each other.
Brian
> Brian
> --- In AVR-Chat@yahoogroups.com, "Dave McLaughlin" <dave_mclaughlin@> wrote:
> > Dave.
2010-01-03 by Dave McLaughlin
Hi Brian,
If you look in the code for the Atmel driver you will find a Function in
CAN_DRV.H called Can_config_tx()
This sets the following register to start the transmission.
CANCDMOB |= (MOB_Tx_ENA  << CONMOB)
There is other stuff you need to setup before calling this. Look for the
function can_cmd() in CAN_LIB.C as this show the sequence needed to config
before sending. Look for the case CMD_TX_DATA and you will see what I mean.
Good luck and if you need more help let me know.
Dave.
Of blue_eagle74
Sent: 03 January 2010 08:20
Brian
--- In AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com> ,
> Brian
> > Dave.
