AVR-Chat
RE: [AVR-Chat] Re: small sd card
2010-02-18 by Tim Mitchell
----Original Message----
[mailto:AVR-Chat@yahoogroups.com] On Behalf Of blue_eagle74
Sent: 18 February 2010 02:14 To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] Re: small sd card
> Well, I guess standard SD cards for cameras and such.
> Wanted to use the SPI fuction of the card instead of the
> 4 bit mode. I have one made by Panasonic, 256M, not sure
> if this has the spi option. There is a guy sending me one
> that is 128M. I initally wanted a small one like a 16M
> because the data I am saving is quite small, using 512K
> eeprom right now.
> I haven't looked into it yet (I know 'google'), but is
> there a specific way to save data to the card so when the
> card is put into the computer it will open in excell? Do
> I just add ascII charactures for comma between the data?
Not so simple unfortunately.
To do this you have to create a FAT filesystem on the card (or format
the card in the PC and use the filesystem thus created).
Have a look at FatFS which is a neat library for doing this (if you're
working in C). You just need to add functions to read and write a sector
of data to/from the card. Then it gives you standard file
open/read/write commands.
http://elm-chan.org/fsw/ff/en/sfatfs.html
If you name your file "xxx.xls" and put commas between the data, then
when you put the card into the pc and open the file, it would open with
excel (assuming your windows file associations are set up right).
Tim Mitchell
Re: small sd card
2010-02-20 by blue_eagle74
I have seen that document on avr freaks. I WILL have to do some more reading in the SanDisk Secure Digital Card Product Manual. I was under the impression I could communicate to the card just like the eeprom I am using by giving a command to write and the address to start at. I have much more to learn. Thanks for your help.
Brian
> From: AVR-Chat@yahoogroups.com
> > eeprom right now.
> Tim Mitchell
