AVR-Chat
CRC using IAR compiler
2010-05-05 by Philippe Habib
I'm using the IAR compiler V5.11 or 5.12 and need to use the feature
that has the linker write a CRC in the last two bytes of the executable.
I got the linker to write the CRC and I am able to read it back.  The
problem is, I can't manage to compute the same one.  I have tried
several different routines to generate the CRC and they agree with
each other, but not with what IAR computes.  In each case, it is
supposed to be a CRC 16 of the CCITT variety with 0x1021 as the
polynomial.
Has anyone gotten this to work?  Is there some sample code somewhere
that has been shown to work with the IAR computed CRC?
Thanks.
Re: [AVR-Chat] CRC using IAR compiler
2010-05-05 by wagnerj@proaxis.com
> polynomial.
> Thanks.
Phillip -
There are a number of "standard" initial conditions for the polynomial, I
think. Each one gives a different result. I am using IAR, against my
better instincts, but its at work and I am 300 miles from there. I will be
happy to check when I return on Thursday.
Jim Wagner
Oregon Research Electronics
> polynomial.
> Thanks.
PS - sorry for misspelling your name!
Jim Wagner
I am using 0 as the initial value.  I tried building the CRC from 0 to
the end of file -2 (the CRC is in the last 2 bytes) and also going the
other direction down to 0.
Thanks for the offer to look.
>> executable.
>> polynomial.
>> Thanks.
> Phillip -
> polynomial, I
> will be
> Jim Wagner
2010-05-06 by Bob Paddock
That will miss inserted leading zeros.  Using 0xFFFF will not have that
problem.
Also if you store the ones compliment of the CRC, low byte first, at the end
of your data, when you CRC that as part of your data you will end up with a
"Magic Number", that will always be the same if the CRC is good.  0xF0B8 is
common for 0x1021 polynomial.  It could also be 0x1D0F in reverse bit order.
 Take a look at the CRC section in http://www.boost.org for a good write up
on CRCs.
2010-05-10 by Philippe Habib
Jim,
Did you happen to get a chance to look at this?  I got pulled off to
something else for a few days but I'll be getting back to it soon.
Thanks.
>> executable.
>> polynomial.
>> Thanks.
> Phillip -
> polynomial, I
> will be
> Jim Wagner
2010-05-10 by Jim Wagner
Sorry, forgot all about it. I'll check in the morning at work.
Jim
On May 9, 2010, at 9:58 PM, Philippe Habib wrote:
> Jim,
> Thanks.
> feature
> >> executable.
> The
> >> polynomial.
> >> Thanks.
> > Phillip -
> > polynomial, I
> > will be
> > Jim Wagner
> > Yahoo! Groups Links
