AVR-Chat
[AVR-Chat] Re; CRC using IAR compiler
2010-05-11 by wagnerj@proaxis.com
Hello, Phillipe
I did some digging through the IAR docs.
In the Linker documentation, it shows you how to generate and view the CRC
of various linked modules. And, if you search that same document for
"checksum", you will find a description of their checksum algorithm that
can be included in code, as in a bootloader.
Hope this helps
Jim
Re: [AVR-Chat] Re; CRC using IAR compiler
2010-05-12 by Philippe Habib
I got that far too.  I can get the CRC placed into the file, and I can
read it.  My problem is I can't generate one that matches the one in
the file.  I tried several methods and while they agree with each
other, none agree with the IAR one.
I've seen the same problem raised in the AVR forum, but the people
who've solved it never post the resolution.
I'll have to back off and take a fresh look.
On May 11, 2010, at 1:18 PM, wagnerj@proaxis.com wrote:
> Hello, Phillipe
> the CRC
> that
> Hope this helps
> Jim
2010-05-12 by wagnerj@proaxis.com
Are you comparing an internally generated CRC to the CRC generated by
their published algorithm?
Or are comparing a CRC generated by their published algorithm against
something computed elsewhere?
Also, make note of the fact that what is saved in memory MAY be the
complement (I think thats it) of the real CRC such that when you run the
CRC test over the ENTIRE code (including the CRC), you get some
"well-known" value, such as 0x00.
Jim
> Thanks,
>> Hello, Phillipe
>> the CRC
>> that
>> Hope this helps
>> Jim
>> Yahoo! Groups Links
Re: Re; CRC using IAR compiler
2010-05-12 by ecros_technology
--- In AVR-Chat@yahoogroups.com, David Kelly <dkelly@...> wrote:
> There is a lot of debate as to
> how a CRC should be calculated.
I think this is true only in circles where the precise meaning of "CRC" is not understood.  The mathematics of cyclic redundancy checks has been extensively studied and optimal solutions exist for just about any situation you can imagine.
On the other hand, people are inclined to use the term CRC to mean any kind of redundant data transmitted or stored along with any piece of data that may be received or recovered with errors.  A checksum, for example, is much easier to compute than a CRC but offers inferior protection against errors.  This, I think, is where the debate happens.
Graham.
2010-05-13 by David Kelly
On May 12, 2010, at 10:09 AM, Philippe Habib wrote:
> Thanks,
I'm tuning in late but if you are having problems replicating the result of IAR's CRC calculation then perhaps one should ask IAR how the value is calculated?
There is a lot of debate as to how a CRC should be calculated. In the past when I studied this issue there was one school of thought that the last bits fed to the CRC generator were weaker than all the other bits previously fed. Their solution was to "close" the calculation by always pushing 0xffff (or some such known value) into the CRC checksum as the very last values added.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
2010-06-01 by Jim Wagner
Did this ever get solved?
Jim Wagner
On May 12, 2010, at 8:09 AM, Philippe Habib wrote:
> Thanks,
> > Hello, Phillipe
> > the CRC
> > that
> > Hope this helps
> > Jim
> > Yahoo! Groups Links
2010-06-01 by Philippe Habib
Not yet.  I have been buried in an unrelated issue and have not looked
at it for a while.
> Jim Wagner
>> Thanks,
>>> Hello, Phillipe
>>> the CRC
>>> that
>>> Hope this helps
>>> Jim
>>> Yahoo! Groups Links
Thanks
Jim
> at it for a while.
> > Jim Wagner
> >> Thanks,
> can
> >>> Hello, Phillipe
> >>> the CRC
> for
> algorithm
> >>> that
> >>> Hope this helps
> >>> Jim
> >>> Yahoo! Groups Links
> > Yahoo! Groups Links
