RE: [AVR-Chat] ATMega644 to replace an ATMega32A, Need new JTAG?
2011-01-21 by Tim Mitchell
I recently upgraded a project from Mega16 to Mega164PA which is very similar to what you are doing. You shouldn't have any problems except a lot of the register names need changing, and the timer setup is slightly different. If you are programming in assembler (which I seem to remember you aren't) then most of the registers have become sram addresses rather than io addresses so you have to use str-ldr instead of out-in instructions, in C this will happen automatically. I don't use JTAG on it so can't help there. -- Tim Mitchell
2011-01-21 by H. Carl Ott
For JTAG (and DW and PDI) on the more current chips a Dragon for about $50 USD is probably the way to go. I managed to blow up my first gen. dragon (there were problems), but supposedly the new ones are far more robust. I've been using a real Atmel JTAGICE MKII for a couple of years now. It's great, but I think it's too expense at $300. There are promotions fairly often where you can get a MKII at half price (from distributors like Avnet). At $150 I think it's worth it. That's what I paid for mine. carl -------------------------------------------------------- Henry Carl Ott N2RVQ hcarlott@gmail.com > > > [Non-text portions of this message have been removed]
2011-01-26 by Chuck Hackett
Thanks to all for your help on my possible conversion from the ATMega32A to the ATMega644. I took another look at my application setup and decided to remove FreeRTOS due to the fact that: 1) This application didn't really need it, but I was using the opportunity to learn about FreeRTOS with an eye to using it in future projects. 2) FreeRTOS was consuming significant code space and, more critically, having to allocate multiple stacks large enough to handle the max stack depth, including interrupts was really straining things in 2k of SRAM. It didn't take me long to re-organize things into a more typical "Work Loop w/interrupt handlers" structure. > From: H. Carl Ott > > For JTAG (and DW and PDI) on the more current chips a Dragon for about $50 > USD is probably the way to go. > I managed to blow up my first gen. dragon (there were problems), but > supposedly the new ones are far more robust. > > I've been using a real Atmel JTAGICE MKII for a couple of years now. It's > great, but I think it's too expense at $300. > There are promotions fairly often where you can get a MKII at half price > (from distributors like Avnet). At $150 I think it's worth it. That's what I > paid for mine. Thanks Carl, I'll do some poking around on prices. I'll need it eventually ... > From: ecros_technology > .... > Mike Payson is correct in his analysis. The AVR ICE-Cube, as a "clone" of the > original Atmel JTAG ICE, supports only a short list of devices, that were the > first AVRs to use JTAG, plus the new variations of them, i.e. the "A" parts. > I also agree with everything else that has been written in this thread, > including 1) you should not have much trouble doing what you're proposing to > do and 2) the AVR Dragon is a decent choice for a new JTAG interface. I don't > know much about this business of them being fragile, however, as I bought mine > as soon as they came out and have had no trouble at all. Yea, but Graham, I've gotten so used to having the Ice-Cube sitting on top of my boards, things just won't be the same! :-) Cheers, Chuck Hackett "Good judgment comes from experience, experience comes from bad judgment" 7.5" gauge Union Pacific Northern (4-8-4) 844 http://www.whitetrout.net/Chuck
