AVR-Chat
Mega644 Brown Out Detector Problem
2011-09-15 by Phillip Vogel
I'm having what I hope is a minor problem. My circuit contains a mega644p powered by a lithium battery through a 3.3V regulator. There is a 12MHz crystal, and the CKDIV8 fuse is set, resulting in a clock speed of 1.5MHz.
If I set the brown out detector to 2.7V, the chip never comes out of reset. It starts up OK if I set the BOD to off or 1.8V, but not 2.7V. I have checked the supply voltage, and it is, indeed, 3.30V.
What am I missing here?
Re: Mega644 Brown Out Detector Problem
2011-09-15 by greggy
The regulator probably needs 1 - 1.5 volts head room, which your battery is not supplying. Just remove the regulator. Or use two batteries in series to push the voltage up.
RE: [AVR-Chat] Re: Mega644 Brown Out Detector Problem
Nope. This is a low dropout regulator, and there is plenty of battery voltage. The supply voltage to the chip IS (not "is supposed to be") 3.30V.
> From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On
> Behalf Of greggy
> Sent: Thursday, September 15, 2011 3:36 PM
> To: AVR-Chat@yahoogroups.com
> Subject: [AVR-Chat] Re: Mega644 Brown Out Detector Problem
> speed of 1.5MHz.
Re: [AVR-Chat] Re: Mega644 Brown Out Detector Problem
2011-09-16 by R E Purcella
What is your voltage ref set to?
rep
> 3.30V.
> > From: AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com>
> [mailto:AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com>] On
> > Behalf Of greggy
> > To: AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com>
> > --- In AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com>,
> > speed of 1.5MHz.
> > Yahoo! Groups Links
2011-09-16 by M W
If the LDO Regulator isn't bypassed properly it can oscillate, that could cause the Brown Out Reset to be firing when it drops, possibly? (If you don't bypass properly, it will bite you, it's bitten all of us probably LOL)
Long day so that's all that I can think of ATM.
  Mark
--- On Thu, 9/15/11, Phillip Vogel <phillip@bartal.com> wrote:
> From: Phillip Vogel <phillip@bartal.com>
> Subject: RE: [AVR-Chat] Re: Mega644 Brown Out Detector Problem
> To: "AVR-Chat@yahoogroups.com" <AVR-Chat@yahoogroups.com>
> Date: Thursday, September 15, 2011, 12:46 PM
> 3.30V.
> On
> > Behalf Of greggy
> Problem
> which your
> Or use two
> circuit contains a
> regulator. There
> > speed of 1.5MHz.
> never comes out of
> 3.30V.
