I am just catching up with this thread. In my real life I use SVN semi-often
and it works fairly well with my clients that have multiple employees
accessing the repository. Or -> it translates fairly well to a
multi-contributor project. For OS clients, we use Tortoise SVN on Windows
machines and run command line from Linux and Mac. There are also free
services for hosting SVN as long as the size of the repository remains
within the constraints of the services, which are fairly generous. One free
service that I have used is projectlocker.com . My experience has been very
good with them. Upon looking, they only allow 3 users for free but there are
other similar services out there.
On Tue, Oct 25, 2011 at 12:44 AM, Brian Dean <brian@bdmicro.com> wrote:
> Hi Chuck,
> We've been very happy with good old CVS. All of our AVR development
> projects, among many others, are under CVS control. We do frequent backups
> of the repository, and the repo is composed of a simple directory structure
> of flat files so it is easy to do a complete backup to a thumb drive to
> carry with you for a little extra peace of mind.
> It may not be the glitzyest thing out there, but it works well and is easy
> enough to use.
> Give subversion a look as well, it's a bit more modern, but CVS works fine
> for us and make remote/shared development easy if/when you decide you need
> to support that.
> -Brian
> Brian Dean
> BDMICRO LLC
> http://www.bdmicro.com
> On Oct 24, 2011, at 12:51 PM, Chuck Hackett wrote:
> > One of my AVR projects has grown to a significant number of files and
> > complexity. I also need to track multiple versions installed in the
> field,
> > multiple development/bug fix lines, etc. so I'm looking for a
> Source/Version
> > Control package to manage it.
> > This is for single developer only and is restricted to one development PC
> > (Windows 7, 64-bit) so I don't need features for remote hosted
> repository,
> > cooperative development, etc. (but if there, I may use them in the
> future).
> > My primary tools are: CodeBlocks for development IDE, WinAVR compiler and
> > AVRStudio for debugging.
> > Checkin/checkout integrated into CodeBlocks would be nice but is not a
> > requirement.
> > At the moment I am trying out CS-RCS Pro (free version) by Component
> > Software as recommended by a white paper I found on AVR Freaks and it
> works
> > ok but there may be something better out there that I should look at
> before
> > I commit a lot of time and versions to it.
> > I also develop programs using Microsoft Visual C# as part of this project
> > (PC program that communicates with the field AVR based devices) so it
> would
> > be a plus if I could use the same package to support Visual C# projects.
> > Any recommendations of packages I should look at?
> > Thanks in advance for your time .
> > Cheers,
> > Chuck Hackett
> > "Good judgment comes from experience, experience comes from bad judgment"
> > 7.5" gauge Union Pacific Northern (4-8-4) 844
> > <http://www.whitetrout.net/Chuck> http://www.whitetrout.net/Chuck
> > [Non-text portions of this message have been removed]
