PWM based audio
2012-08-04 by englsprogeny1
Hi guys, I want to start including audio in my projects a bit more. So far I've designed using MP3 modules that I purchased on EBAY. I now want to design using the AVR's 16 bit PWM to create audio. I've found a project that does this: http://elm-chan.org/works/sd20p/report.html When I download and build the 'firmware' found at: http://elm-chan.org/works/sd20p/sdsg.zip Everything builds ok. Unfortunately when I change the processor from attiny861 to an attiny2313 (in the makefile) the build does not work. ### Target device #DEVICE = attiny861 DEVICE = attiny2313 Build results: main.c : avr-gcc -c -std=gnu89 -gdwarf-2 -mmcu=attiny2313 -Os -mcall-prologues -Wall -Wextra -DF_CPU=16000000UL -DMODE=2 -Wp,-M,-MP,-MT,obj_hr/main.o,-MF,obj_hr/main.d main.c -o obj_hr/main.o main.c: In function 'chk_input': main.c:93: error: 'GIFR' undeclared (first use in this function) main.c:93: error: (Each undeclared identifier is reported only once main.c:93: error: for each function it appears in.) main.c: In function 'audio_on': main.c:135: error: 'PLLCSR' undeclared (first use in this function) main.c: In function 'wait_status': main.c:178: error: 'PCIE1' undeclared (first use in this function) main.c:179: error: 'WDTCR' undeclared (first use in this function) main.c: In function 'main': main.c:339: error: 'WDTCR' undeclared (first use in this function) main.c:341: error: 'PCMSK0' undeclared (first use in this function) main.c:342: error: 'PCMSK1' undeclared (first use in this function) make.exe: *** [obj_hr/main.o] Error 1 > Process Exit Code: 2 > Time Taken: 00:01 ---------------------------------------------- Looking at the datasheet for the attiny2313 I don't see the GIFR (register) and others listed above. I thought that the register structure for all AVRs would be the same or at least the same within the 'tiny_xx' versions. When I change the processor to an atmega8 I get different issues with the build. It points to the assembly file within this project. I thought that assembly was the same across all AVR processors. Thanks for any input. I'm not stuck with implementing this project using the source that I found above (If anyone has any other suggestions).
