Re: Same code different results
2013-07-27 by englsprogeny1
When I rebuild the hex file I use and exact copy of the 'archived project same project (same makefile). It seems that the optimization would be the same. I did try what you said and updated my makefile to set optimizations to zero. I still have the same issue (twi does not work correctly). Iw roks right after boot but any slave (1307) reads therafter do not work). When I load the target with my archived hex file, all works well. TWI, UART, EEPROM support files are in this project, as well. Something that may be different since I did the build that works... I've rebuilt my machine. This new machine is Windows 7 while my previous machine was Windows Xp. I'm not sure if I've had this hex file built and running properly since then (but it seems that I have). All other functions work in my new builds except for this twi. I copied the same AVR lib (in the same directory) that I used on previous builds. --- In AVR-Chat@yahoogroups.com, Cagri Tanriover <dr_cagri_tanriover@...> wrote:
> > > I would check the project's optimisation settings. If your project is highly optimised, timings and similar type of problems may occur depending on the types of optimisations. I would try to remove all optimisations to start with to see if it all works as expected first. > > I had a similar problem where no apparent changes appeared in the code except a few mild optimisations and the whole code went haywire. Innocent looking optimisations can cause a lot of headaches. > > > Regards... > > > [Non-text portions of this message have been removed] >
