TWI not working when optimization is on
2013-08-07 by Chuck Hackett
I have a large program that uses TWI to interface to an LED controller and a
24xx64 EEPROM.
All works fine until I turn on optimization (-O). With optimization on I
get "Start Failures". I am not using interrupts with the TWI interface
(wait loops). I have code that waits for the interrupt bit to come on, etc.
as shown in the data sheet.
Here is one of the functions (c++):
uint8_t TWI_cl::TWI__SendStart( void )
uint8_t twst;
TWCR = _BV(TWINT) | _BV(TWSTA) | _BV(TWEN); // send start condition
while ((TWCR & _BV(TWINT)) == 0)
; // wait
for transmission
twst = TW_STATUS;
// Determine if we have entered the started state
switch (twst)
case TW_START:
case TW_REP_START:
State = TWIState_Started;
break;
default:
break;
return twst;
I can post more code if needed but I thought that I would just give a high
level description to see if someone else has had a similar problem.
I have looked at the code emitted and it appears that the TWINT bit is being
reloaded correctly so it does not appear to be a "volatile" issue with the
TWCR register.
My guess is that there is some kind of timing issue going on ...
Processor: Atmega1284p
WinAVR: WinAVR-20100110
Chuck Hackett
"Good judgment comes from experience, experience comes from bad judgment"
7.5" gauge Union Pacific Northern (4-8-4) 844
http://www.whitetrout.net/Chuck
